Old 19-12-2017, 06:10 AM   #1
Default G13B angle?
Ok guys,
I'm rebuilding and upgrading friends Mini with G13b in it and one of upgrades are Suzuki Throttle bodies.
I would like to order a kit from Danst Engineering.
There is a kit with TBs on a custom intake ready to be mounted on the engine.
My question is!
What angle do I have to look for in the intake to clear the bulkhead?
I think it's offered in 20 degrees but I can ask for a different angle if needed...
The engine will be sitting in Allspeed frame.
This info would save me one time subframe and engine mounting on the car
https://www.facebook.com/BrutalacGarageZagreb/
Old 20-12-2017, 09:17 AM   #2
99fusion
Location: A funny little country with more special beers per capita than anywhere else
Nice little find! Any reason for GSXR600 throttle bodies over gsxr1000 which most people with g13bs seem to go for?
Can't answer your question, but maybe you can knock up a CAD (binky style) envelope of the volume available from cylinder head inlets to bulkhead then draw that up as a proper CAD model, andsee what fits inside that?
Just an idea...
99fusion is online now   Reply With Quote
Old 25-12-2017, 11:58 PM   #3
minsuki
CC: 993
I’m not sure what angle the manifold has to be, but the engine itself does
Lean forward at a 20 degree angle. That clearance also on depends on how high or
How low the engine is mounted in the frame.
Minisuki
minsuki is offline   Reply With Quote
