Old 22-12-2017, 11:33 AM   #286
Doing a few trim bits last night, added number plate lights and door rubbers etc.
Hadn't run in a few weeks so gave it a quick rev
Old 24-12-2017, 07:15 AM   #287
Sounds tame.
InstantCustard is online now   Reply With Quote
Old 24-12-2017, 11:51 AM   #288
sounds like a 2 stroke lol are you going to get away with it?
or is it the mic,
Old 24-12-2017, 07:38 PM   #289
Might be the garage / phone but it's certainly not quiet!
I'll check the noise level at some point, it might end up with a different exhaust
Old 24-12-2017, 07:53 PM   #290
What type of exhaust are you running.
I just had a single silencer box on my old VVC and from memory it was 96db noise tested
Old 24-12-2017, 10:56 PM   #291
It's a Hornet kit. It's basically a cheery bomb mid section and another cherry bomb at the back.
Old 24-12-2017, 11:00 PM   #292
https://m.ebay.co.uk/itm/Hornet-Univ...-/121503928239
Old 01-01-2018, 10:50 PM   #293
Not done a huge amount over Xmas but there isn't loads left to do really!
Insurance bought and paid for, starts in a few weeks.
Fitted the washer bottle and plumbed in the jets.
Blue interior, ordered some padding for the cage.
Started making some door cards in Ally
Old 05-01-2018, 11:53 PM   #294
will16
will16's Avatar
ECU: K Maps 170
This is really cool, top quality work Sounds raw aswell, I shall be buying one of those hornet kits for mine!
will16 is offline   Reply With Quote
Old 06-01-2018, 02:49 PM   #295
They do seem good value, it might be a bit on the loud side though, need to measure it.
Old 11-01-2018, 09:59 AM   #296
Old 14-01-2018, 10:51 AM   #297
Where's the allargo badge?
AGoaty is online now   Reply With Quote
Old 14-01-2018, 09:53 PM   #298
It felt appart so I glued it back. Went to fit it and the original pegs put stress on the joints, crack. Had a new factory one so stuck that on for now, May get changed again later !
