Old 01-12-2013, 11:22 PM   #106
revingtosh
CC: 1600cc
Yes im sure that will be fine. Just make sure that its all FT before you move on. To be completely honest, I cant remember as it was a few years ago. I do remember a few phone calls to Rob Hall at Allspeed for advice though!
revingtosh is offline   Reply With Quote
Old 25-02-2017, 05:02 PM   #107
revingtosh
CC: 1600cc
Its been a minutes.. how is everyone doing?
Im thinking about another project - possibly Mini related. Has there been any change in the UK laws surrounding these mini projects in recent years? Are all we all still good to go?
Old 01-03-2017, 01:34 PM   #108
player14
Send a message via MSN to player14
I'm still building my c16se too! Out of curiosity did you use the standard crank pulley? And which rad did you use?
www.eastcoastminis.org.uk
player14 is offline   Reply With Quote
Old 02-03-2017, 09:24 AM   #109
revingtosh
CC: 1600cc
Standard crank pulley mate. Mini MPI Rad is good - Daewoo Matiz rad was better again
Old 20-03-2017, 08:07 PM   #110
Basil
CC: 1598
Send a message via MSN to Basil
have you got any pics of the Matiz radiator fitted?
Basil is offline   Reply With Quote
Old 26-03-2017, 10:38 PM   #111
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Be good to see you back on with a Mini project Mike
Sent from my iPad using Tapatalk
I've got 3 long studs in my hand.
NudgerSS is online now   Reply With Quote
Old 24-04-2017, 08:46 PM   #112
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
I'm assuming Big Bad Barry has taken over now?
Old 14-05-2019, 11:23 AM   #113
revingtosh
CC: 1600cc
Big Bad Barry has been and gone mate - I replaced BBB with a type 4 Scimitar GT.
Old 15-05-2019, 01:02 AM   #114
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
I know it has now but back in April 2017 when i posted it hadnít! Iím assuming you donít come on here much Mike
