Go Back   16v Mini Club Forums > Builds > Other Mini Builds
Old 17-04-2019, 08:29 PM   #136
evenbiggerdave
Originally Posted by Oz View Post
I am only doing a kind of like for like subframe swap, my pedals were already modified to fit the old frame and the steering rack is in the same position.
Do you have any pedal pics mate?
Dave
evenbiggerdave is offline   Reply With Quote
Old 18-04-2019, 10:41 AM   #137
The car is in pieces at the mo so nothing of any use I can take now but this is the only pic I can find that shows them.
Watsons built my car and did the work, they have just been physically bent around the pedela, not cut and welded
Old 18-04-2019, 10:42 AM   #138
He's another pic from this website
http://www.theclubman.co.uk/
Old 19-04-2019, 04:20 PM   #139
evenbiggerdave
Nice one matey thank you! So basically the same as what I have done. I was gonna bent the original pedal, but thought it would obviously ďalter the lengthĒ of it if I added a bend. (Hope that makes sense?), thatís why I cut and welded in some 8mm plate, that way the pedal is exactly sane position/stroke as it was, but with the clearance!!
Itís super hot in the garage today.....I might get our there one eve over Easter and finish the column......then thatís another job jobbed
Dave
Old 19-04-2019, 09:07 PM   #140
evenbiggerdave
Column mounted, bang in centre of seating position, good height, depth etc. Chuffed with it.
The bolt is temporary, and it is only spot welded (had to rush out half way thru), but itís in, solid and working!
I have a removable boss, and a bananasty steering wheel. I will get a new one after the strip down and rebuild commences.
Dave
Old 20-04-2019, 07:08 PM   #141
I took this pic today of my pedals, if it helps any
Old 21-04-2019, 08:30 PM   #142
evenbiggerdave
Thanks man!! If thatís how the professionals do it, Iím happy how mines turned out
Will be welding up my column mounts fully tomor (mrs is out ) then look at coolant pipe work.
Sheís bought me a bead roller for my birthday so Iíll be able to start on the rear bulk head/boxing in panels soon.
Happy days
Dave
Old 08-05-2019, 08:38 PM   #143
evenbiggerdave
Evening!!
Only a quick update......
All stripped, started panelling either side of the cage, bitch of a job, hard to hold, level up and weld, but itís strong!!
Bought some arches other week but far too if so theyíre on eBay.....stumbled across a lovely guy in London and got these for £20!!! Spot on....
Over the moon!!!! Hopefully get some more panelling done this weekend!!!
Dave
Old 11-05-2019, 08:44 PM   #144
becko
ECU: Not sure yet
Looking good pal ... keep the updates coming
becko is offline   Reply With Quote
Old 12-05-2019, 07:44 PM   #145
evenbiggerdave
Literally an hour today......
Will flip it over in the week and weld the upside stuff. Cheers for looking
Dave
