Old 11-02-2018, 12:50 AM   #16
GEORDIE SP1
GEORDIE SP1's Avatar
So Engine and frame set in but boy this CRV box is tight.
Gearbox full forward on mount but still hitting on steering rack, canít pull Engine any further forward or hitting inner guard,
Really if I was starting from scratch I would go for a flip front. So rather than cut up the front, move radiator ETC going to move steering rack
This will bring it back in line with metro steering arms and might make the rack mount adjustable when Iím at it to dial out bump steer.
Old 13-02-2018, 12:29 AM   #17
Good stuff ! Is bump steer less with the back wheels pushing the front along??
I believe the front has less time to get confused!
Old 13-02-2018, 09:23 PM   #18
GEORDIE SP1
Good question, will keep it at standard height to start off and go from there.. see what angle the arms are sitting when I get it on the wheels.
Old 14-02-2018, 10:56 PM   #19
GEORDIE SP1
No going back now, Engine and frame back out, steering rack panel removed, also noticed the gear selector bracket was running close to bulkhead so making at small pocket to clear.
Old 15-02-2018, 12:12 AM   #20
"your at it" I took a look at a crv on the scrap heap
Did I see cranked track rod ends on it? Like a bend in the cast arm?
Old 15-02-2018, 07:36 PM   #21
GEORDIE SP1
Think the CRV ones are cranked so wheel clears them on full lock
Old 03-03-2018, 07:15 PM   #22
GEORDIE SP1
Had a go at making steering rack panel
Itís pretty beefy
Adjusting bolts on top didnít really work out so have to rethink
Just need to trim around the ends and get it all welded up.
Old 04-03-2018, 01:15 AM   #23
Cool as fook !!
Old 11-03-2018, 12:06 PM   #24
GEORDIE SP1
Panel welded in, its only when you start these things you realise your welding to 50 year old steel.
Get it sealed up and bit of paint on tomorrow night.
Old 14-03-2018, 08:27 PM   #25
vfast
CC: 15
Default paint
:dont be mixing paint with beer
vfast is offline   Reply With Quote
Old 14-03-2018, 10:32 PM   #26
GEORDIE SP1
Well I am after that weathered look.
Old 16-03-2018, 10:58 PM   #27
GEORDIE SP1
Well , have painted rack panel, mounted rack at highest position and dog legged the pedals to clear,
Get the engine back in over weekend I hope
Bottom bolts are adjusters,
Old 19-03-2018, 12:20 PM   #28
AWD
nice!
Old 19-03-2018, 10:08 PM   #29
GEORDIE SP1
Thanks AWD, bit more room now
Will get cable change set in shortly, hopefully get it running within the week ,front end !
Changing over to 4x100 wheels at same time.
Old 22-03-2018, 07:02 PM   #30
mikko
mikko's Avatar
ECU: obd0
how you doin the 4x100 mod geordie?
