Old 21-08-2017, 07:10 AM   #16
I have moved the tie bar mounts outward and downwards approx 20-25mm in both directions which has allowed me to also keep the standard oil filter housing ect, the tyres don't rub the tie bars. Also handling seems un-effected (after castor is corrected to standard).
Old 21-08-2017, 11:28 AM   #17
ZA-J
How is your bottom arm bush wear, or are you running rose joints?
Old 21-08-2017, 12:05 PM   #18
standard (genuine rover) rubber bushes all round, been on there 3 years and are still good.
Old 21-08-2017, 12:25 PM   #19
ZA-J
That's good to know, thanks.
Old 21-08-2017, 12:54 PM   #20
ZA-J
My alternator has arrived too - Lightweight 50A unit from Brise - only 100mm external diameter.
Old 15-10-2017, 06:48 PM   #21
ZA-J
Plenty of progress since my last post, I've just been rubbish at updating the thread!
First bit of subframe
Tacking together
Working out suspension arm angles and mounts
Basic frame roughly built
Update by Andy Walker, on Flickr
We've tried to keep original parts as much as possible, even it if means heavily cutting and welding them!
Plenty of welding!
.......and rust repairs!
Almost finished (Drivers side frame has since been modified for damper clearance)
This weekends job - engine steadies
Another steady mount on the cross brace
Whilst my brother works on the exhaust manifold
time for a beer.......
Old 15-10-2017, 06:58 PM   #22
ZA-J
Forgot a few:
Bottom arm mounts
Slight bulkhead mod for inlet plenum
Old 15-10-2017, 07:42 PM   #23
Cracking on! Exhaust manifold is looking good and the engine mounts are great - I'm going to try something similar on the gearbox side on mine. Have a few questions you have probably got it covered, but I'll pipe up whilst you're still in fabrication stage. Why did you decide to use captive nuts on the bottom arm mounts? And have you got room to put the bolts in from the back when the frame is on the car? I think it's pretty tight and would be a shame to make bottom arm bush replacement a subframe out job. Also have you put the hubs on to check you have enough suspension travel. If you fit top & bottom arms and connect the hubs I think you may find the bottom arms hit the frame before the top arm hits the droop stops. You may be ok, but I spotted this problem on mine whilst mocking up.
Old 15-10-2017, 07:44 PM   #24
Scratch the bit about no room for bottom arm bolts, I was thinking of top arms
Old 15-10-2017, 08:15 PM   #25
ZA-J
Bottom arm bolts aren't captive nuts - its a nut welded on the end of the original pin. Nut is there to aid removal and installation and tightening it up.
Old 15-10-2017, 08:17 PM   #26
ZA-J
More up to date overall view of the subframe......drivers side frame rail has a shallower angle to allow damper removal and installation
Old 15-10-2017, 08:19 PM   #27
ZA-J
Good shout, Will have to take a closer look....thanks!
Old 15-10-2017, 08:26 PM   #28
ZA-J
And a little side project, turning the smashed up gearbox that started this project into a coffee table!
Starting point
Gears out, case ready for machining
Brother machined down the casing flat.....off to the blasters next
Old 17-10-2017, 07:22 PM   #29
ZA-J
We're playing clutches tonight. I've opted for cable clutch to gain most space in the engine bay for rad, but am struggling to work out how much throw the hook on the clutch pedal needs. I've read somewhere that the throw needs to be 60mm, but for that to be the case with the mini pedal, the hook needs to be about 95mm away from the pivot point.
Is 60mm optimum throw measurement?
Old 17-10-2017, 09:29 PM   #30
http://www.16vminiclub.com/showthrea...t=27565&page=4
About half way down shows how I did it.
