Old 17-05-2017, 01:59 PM   #16
Originally Posted by edk83 View Post
Just read this beginnings of thread and the car seems to have a lot of potential, hats off to you sir.
Looking forward to your turbo build, hows about a supercharger as well ?
I want this to be reliable with over 200bhp. It will happily cruise on motorway journeys due to the big wheels. Gonna be an awesome track car. Not focusing on massive power. There is always someone quicker or prepared to spend more.
Old 19-05-2017, 11:27 AM   #17
Cliff Pountney
Andrew,
Stripping the unused circuits out of the MGF loom may seem like a ball ache but it's worth it. This is a picture of what I removed, saving 3.5kg.
Cliff
Old 19-05-2017, 01:43 PM   #18
Originally Posted by Cliff Pountney View Post
Andrew,
Cliff
Yes I did same when I did Phoenix. It did take a while. The car has central locking already. Looking into doing electric windows too...
Not sure but stuff like the ABS, air con etc will want removing. The current loom is just the original all tucked away under the dash.
EDIT. Electric window winders purchased...
Old 19-05-2017, 03:15 PM   #19
CooperWorks
CooperWorks's Avatar
ECU: Mems 3
Thumbs up
Electric windows? You is well posh.
Old 21-05-2017, 03:51 PM   #20
Electric window winders.
Looked at the suspension setup. It is actually built on Hi Lo's. They look like they are wound up to their limit. May have to shorten the unit it get it lower. Could be interesting as also look like not been moved for years....
Old 21-05-2017, 05:36 PM   #21
If you want this to be more track focused, would you not be better off going with coilovers?
Old 25-05-2017, 03:08 PM   #22
Seen too many people ruin good cars by fitting coilovers so not going down that route. The suspension does work ok. Just needs adjusting to my my liking.
MG TF Trophy wheels and tyres collected. As expected the tyres make them look massive! I'll give these a trial over the weekend...
Old 29-05-2017, 06:57 PM   #23
I imagine the coil setup fitted as standard to the TF would ride too high?
Old 29-05-2017, 07:45 PM   #24
The subframes on the car have been narrowed to fit a Mini. They have Mini subframes at the top to hold the cones with Hi lo's but are MG F main frame, just narrower. I have no intention of altering that otherwise I may of well as just started from scratch and built my own.
Old 06-06-2017, 06:28 AM   #25
I had to prove this as it caused an argument over buying the Mini. The cams are the standard 118bhp ones which are fitted to this engine in the factory. I have looked over the engine and cannot find any modifications to make more power.
Opened out the MG TF wiring loom. Looks like hours of "fun"!
I have bought Charly's old engine. It needs a rebuild but has most of the bits I need.
Also bought the GT25 turbo he was running on it.
He has also included the alloy inlet manifold from a 135 MG TF.
The Trophy wheels came with tyres but are far too big for the Mini. I have invested in a set of Toyo Proxes T1-R.
These are almost identical in circumference to the ones fitted now. The bigger wheels will mean the AP brakes should go straight on.
Braided brake hoses made quite a bit of difference to the pedal feeling on Phoenix so think I'll invest in those too.
Old 07-08-2017, 11:39 AM   #26
Unfortunately this had to take a sideline as Phoenix's engine developed problems which ended up with another engine.
So now I have a bit of time again it's back to it.
Been buying more bits but not really doing much to the car. So decided to fit the engine cam cover back on and see it it would run, which it did on first turn of the key! The engine is really good. Shame it's coming out. Tried the clutch and brakes which are getting rusty due to being stood, outside. Anyway, everything seems to work as it should.
I think I have most of the parts needed now for the conversion. I have done this video in order to advertise the engine. There will be other parts available from this as it's a MEMS 1.9 and am swapping the entire car wiring to MEMS 3.
Old 07-08-2017, 07:01 PM   #27
richie08
richie08's Avatar
CC: 1396
ECU: Rover mems
Your timing is awful, this would have been ideal for my mems1.9 clubby to upgrade from the 1400 in there
Old 08-08-2017, 01:54 PM   #28
I told you about this 2 months ago. This would go straight in yours without any alterations.
Sorry!
Old 08-08-2017, 06:21 PM   #29
richie08
richie08's Avatar
CC: 1396
ECU: Rover mems
Sorry!
I know! Back in march, before i spent a fortune on VVC rebuild stuff would have been better lol. But i assume you never owned ot back then
Old 15-08-2017, 02:52 PM   #30
After a MG ZR conversion came up on Facebook which had the K series turbo engine fitted and was a reasonable price, I decided this had enough bits on to buy it. The seller stated the engine was good and could be shown to run sweet. So I had it delivered here. Before he unloaded it I said I want to see and hear it running. He said fine. The key is in it. Turned key, nothing. Opens bonnet, no battery. Goes for jump pack. Looks at wiring, no ECU. Said to guy, "you having a laugh here pal?". It's here somewhere and starts routing through piles of bananase in the car. After about 10 mins he found it. So I plugged it in and the car eventually turned over. It fired, but wouldn't run. Just coughed and died. The guy claims it ran fine but I was not happy at all. The rest of the car was covered in dents, interior was worst I have ever seen. Odd tyres. Knackered disc brakes due to rust. So I told him to take it back. Shame really as it had most of the conversion parts I need to carry on this.
So I have taken Chary's engine down to reconditioners. It's having a full strip down to assess what is needed to make it good again.
I also have bought some braided brake hoses.
