Old 08-12-2016, 07:20 AM   #31
jackjewell93
ECU: Emerald
Going to buy a turbo blanket plus lots of heat reflective tape
Old 17-12-2016, 05:19 PM   #32
jackjewell93
ECU: Emerald
Made a start on the body work today took hours to get the roof back to bare metal!
Old 17-12-2016, 05:34 PM   #33
asahartz
That's always a long job!
Old 17-12-2016, 05:38 PM   #34
jackjewell93
ECU: Emerald
Yeah I'm just taking the roof back to bare metal as you can see from the pics it's bad! But once all the pineapple was off there was only a couple small dents.
Old 17-12-2016, 07:53 PM   #35
I did the same with mine, unfortunately it was between 1/16 & 1/8 thick in paint! took bloody ages to strip it all off only to find the reason it was so thick, was that it is covered in ripples and small dents. I have filled to my best ability just hoping that some good thick coats of high build will fill the rest in.
Old 18-12-2016, 12:51 AM   #36
asahartz
Done it a couple of times before, and I have to do it to my Elf when I get my garage clear enough to get it in! I've even replaced a roof before; not a job for the faint-hearted, it would have to be a rare car to make it worth doing that again!
Old 18-12-2016, 08:31 PM   #37
jackjewell93
ECU: Emerald
Got a bit more prepped today roof is now 99% finished also took the doors off and stripped them down bloody hate doing body work!
Old 18-12-2016, 08:52 PM   #38
its the only time I would recommend cutting a batterd roof off and bonding a f/g or similar type on!
Old 27-12-2016, 04:37 PM   #39
jackjewell93
ECU: Emerald
Old 28-12-2016, 09:28 AM   #40
Nice to see some progress. What have you used there? Some sort of spray-on sound deadening?
Old 28-12-2016, 10:00 AM   #41
jackjewell93
ECU: Emerald
Cheers I'm a bit disappointed with the progress over xmas had a week off work and this is all I have achieved, no it's stone chip paint had some left over so used that matches the rest of the underside of the car and I've painted the inside of the boot with it as well on my last build I just sprayed the boot black and it didn't last 5mins so hope this will last a bit longer
Old 28-12-2016, 12:00 PM   #42
Have you tested it to see if the stone chip goes tacky with higher temps?
Could end up with dirty fingers every time you pop the bonnet after a run.
Old 28-12-2016, 12:13 PM   #43
jackjewell93
ECU: Emerald
Just tried it with a heat gun got it so hot couldn't touch it and didn't go tacky.
Old 28-12-2016, 12:14 PM   #44
That's cool then, thought it was worth checking as it's obviously not like normal paint.
Old 28-12-2016, 12:15 PM   #45
jackjewell93
ECU: Emerald
Any one had this happen before? Didn't even make it to full tension!
