Old 30-08-2016, 07:29 AM   #16
All you do is spray the cooler black and then stencil spray the registration numbers in white. Will get the job done nice..
Old 30-08-2016, 10:12 AM   #17
Nice work Jack, keep at it!!.
Had lots of headaches with mine, but now its running well its worth it.. completely different drive to the VVC engine
Old 01-09-2016, 08:57 PM   #18
jackjewell93
ECU: Emerald
The list is slowly getting shorter, made the rear loom also my digital dash arrived, hopefully have all the wiring done this weekend.
Old 13-09-2016, 04:29 PM   #19
jackjewell93
ECU: Emerald
Haven't done much lately. I've sold my roll centre cage and decided to go all out and buy the safety devices multipoint roll cage just got to wait 4weeks for it to arrive!
Old 21-09-2016, 08:03 PM   #20
jackjewell93
ECU: Emerald
Roll cage arrived today so made a start on fitting it.
Old 07-11-2016, 06:34 PM   #21
jackjewell93
ECU: Emerald
Decided to chuck the other dash in the bin and came up with this. Also got the rad mounted, I gave up on trying to buy a intercooler that would fit under the bonnet but found one the same size as the other one I had mounted but this one is a twin pass and made the boost track a lot shorter. I've made a start on the coolant pipes, but I won't have any pics for a while as I lost my temper with my mobile phone and threw it against the wall.
Old 16-11-2016, 10:21 PM   #22
jackjewell93
ECU: Emerald
Old 17-11-2016, 09:15 AM   #23
I'm a huge fan of that! (sorry couldn't help it).
coming along nicely. the rear rad setup works very well on my mates 1.8k mini
Old 17-11-2016, 10:26 AM   #24
Nice work mate!
Old 17-11-2016, 05:25 PM   #25
benvvc
benvvc's Avatar
That rollcage is porn!!
Old 17-11-2016, 06:27 PM   #26
jackjewell93
ECU: Emerald
Thank you for the positive comments! The aluminium sheet arrived today to make up a cowling, should get that made up tomorrow at work.
Old 29-11-2016, 10:00 PM   #27
jackjewell93
ECU: Emerald
So the fabrication of the aluminium ducting didn't go to well ended up with a pile of scrap sheet any way managed to take couple random pics
Old 30-11-2016, 02:10 PM   #28
harrison541
Thats some roll cage!
Old 06-12-2016, 09:28 PM   #29
jackjewell93
ECU: Emerald
Bit more done, made up a flange for the coolant outlet on the top of the head and welded in some bits for the temp sensors, turbo oil feed and drain plumbed and the coolant pipes for the turbo, mounted the header tank, wired the alternator, just waiting on some heat reflective sleeve then the coolant system will be finished
Old 06-12-2016, 09:52 PM   #30
Jack have you thought about the heat from your turbo just below your inlet pipework?
