Old 30-01-2018, 08:37 AM   #136
Why donít you just use a standard engine loom and the necessary adapter loom to plug into the ECU, seems a lot of extra work making a loom when thereís really no need.
Old 31-01-2018, 06:38 PM   #137
jackjewell93
ECU: Emerald
[QUOTE=InstantCustard;376958]Why don’t you just use a standard engine loom and the necessary adapter loom to plug into the ECU, seems a lot of extra work making a loom when there’s really no need.
I could of done what you've said but I want to move the layout of how the loom sits around the engine I could of probably done it with out making a new loom but at least this way it will be 100% spot on and no compromise
Old 31-01-2018, 06:56 PM   #138
Fair enough, can use some of the extra length to try and hide most of the wiring.
Old 09-02-2018, 11:47 PM   #139
jackjewell93
ECU: Emerald
Had dyno session today made 172bhp 6psi of boost with 5k rev limiter to run engine in think it was pulling 250nm of torque rear rad set up worked really well! No marjor issues with it been on the dyno
Old 13-02-2018, 08:27 PM   #140
jackjewell93
ECU: Emerald
Mot booked for Friday
Old 18-08-2018, 12:44 PM   #141
jackjewell93
ECU: Emerald
Finally back up and running made 205bhp 8psi 6k limiter just need to have a look at the gearbox as it’s started to make some funny noises was rebuilt with new bearings and type a lsd fitted that was also new
Old 18-08-2018, 03:57 PM   #142
well done! what sort of noises is the gearbox making?
Old 18-08-2018, 04:55 PM   #143
jackjewell93
ECU: Emerald
There’s a fair amount of Whining when de accelerating
Old 18-08-2018, 05:58 PM   #144
Mine whines on deceleration, I think it has something to do with the steel caged bearings but could be wrong.
Old 18-08-2018, 08:40 PM   #145
Is it consistent with speed or different in each gear? A lot of the pg1 boxes whine due to pitting on the teeth of the crown wheel and pinion gears, it won't cause a problem if its that. The freelanders are especially prone to it due to the extra load from the 4wd system causing pitting more quickly. As said it won't be a problem but if you want to fix it the only cure is to replace the fd with one with no pitting on the teeth
Old 09-09-2018, 04:21 PM   #146
jackjewell93
ECU: Emerald
Default 1.8 turbo (round nose)
Gearbox only makes a noise on de acceleration 5th seems to be worse than other gears, managed to attend open pit lane day at Combe engine was spot on nothing broke just need to sort out couple handling issues
Old 09-09-2018, 06:06 PM   #147
sounds typical of pitting on the cw & pinion teeth, nothing to worry about unless it bothers you
Old 09-09-2018, 08:14 PM   #148
jackjewell93
ECU: Emerald
Thatís kinda good news doesnít bother me to much
Old 16-09-2018, 11:46 AM   #149
jackjewell93
ECU: Emerald
Visited the kad website that was a bad idea also got a Garrett GT2560R to replace the Chinese turbo was to laggy wasnít boosting until 3500rpm
Old 16-09-2018, 12:40 PM   #150
Those alloy front hubs are pure porn. Mostly because they take the bolt on type ball joints!
