Old 10-06-2016, 09:37 PM   #1
jackjewell93
ECU: Emerald
Default 1.8 turbo (round nose)
did have a build diary before the server crashed will add some pics again can't remember what stage the build was at before the crash so will add some pics and carry on from here.
Old 10-06-2016, 09:42 PM   #2
jackjewell93
ECU: Emerald
Old 20-06-2016, 10:07 PM   #3
jackjewell93
ECU: Emerald
Small update clutch pipe made, re-adjusted the alternator to line up better, oil filter pipes fitted, fuel pressure regulator fitted, both front wheel bearings replaced, also painted starter motor and fitted that.
Old 01-07-2016, 09:06 PM   #4
jackjewell93
ECU: Emerald
Boost pipes nearly finished just waiting for a couple bends to arrive also replaced the cv joints made a start on the down pipe but ran out of gas for the welder getting some tomorrow so Will hopefully finish that soon.
Old 17-07-2016, 09:36 PM   #5
jackjewell93
ECU: Emerald
Had a problem with the drive shaft not sitting in the diff correctly, turned out I had the wrong cv joints so ordered mgf one and they fitted perfect but had to remake both shafts
Old 18-07-2016, 09:45 AM   #6
I have to say Jack, you have ruined this with the intercooler stuck out like that. I thought you had the brilliant idea of moving the turbo to keep the standard looks. Now it's dead obvious again what's under the bonnet.
Old 18-07-2016, 05:18 PM   #7
jackjewell93
ECU: Emerald
Never wanted a standard look, just didn't want all the turbo hanging out the front
Old 18-07-2016, 06:33 PM   #8
geachy87
geachy87's Avatar
CC: 1.8t
ECU: Kmaps
Looking good mate.
What's the plans for the rest of the car? I quite like the intercooler on show as long as the rest of the car suits it
Old 18-07-2016, 06:40 PM   #9
jackjewell93
ECU: Emerald
Originally Posted by geachy87 View Post
Looking good mate.
Plan for the rest is side exit exhaust, hole saw the a panels, paint will be a light shade of grey with black roof and interior is stripped out two bucket seats and roll cage.
Old 18-07-2016, 06:57 PM   #10
geachy87
geachy87's Avatar
CC: 1.8t
ECU: Kmaps
Sounds like it'll be pretty smart when it's finished
I'm going to vent the a panels on mine as well but can't decide whether to cut holes in them or buy the vents from abs Motorsport
Old 01-08-2016, 04:20 PM   #11
jackjewell93
ECU: Emerald
So after a couple days of trying to get it running turns out on the 2nd hand head I bought had the cam pulleys was on the wrong dowels so swapped them over fired straight up!!
Old 07-08-2016, 04:13 PM   #12
gouldy847
ECU: MEMS I THINK
hows the build going?
Old 07-08-2016, 09:10 PM   #13
jackjewell93
ECU: Emerald
Slowly, been sorting the wiring out for a couple days.
Old 28-08-2016, 06:34 PM   #14
jackjewell93
ECU: Emerald
Bit more progress, exhaust is made, door cards fitted, made a start on the dash board just waiting for the digital dash to finish that, drilled the a panels, mini loom is nearly finished just got to make the rear half, also have found an intercooler that should fit under the bonnet!
Old 29-08-2016, 03:30 PM   #15
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Intercooler would look better set into the grill I reckon and be a little less vulnerable
