Old 15-06-2016, 05:37 AM   #31
https://youtu.be/SOLVy2f4E88
Bottom end by the sounds of it.. started lacking power on the start finish straight, then death knock, then no oil pressure, then recovery truck home basically... only managed a few laps
Old 15-06-2016, 03:07 PM   #32
https://youtu.be/ohcBz5vDvDY
This is about all the footage i have!... was fun while it lasted
Old 16-06-2016, 05:31 PM   #33
CooperWorks
CooperWorks's Avatar
ECU: Mems 3
Old 16-06-2016, 08:44 PM   #34
Been busy the last 2 evenings
Old 18-06-2016, 07:41 PM   #35
Just to keep this up dated...
After stripping the old engine I found 1 cracked conrod, oil pickup full of bearing shavings and silicone sealer and the engine oil was a nice shade of metalic silver... Yes proper job
I did get this picture that I like, Fair amount of body roll that needs looking at
Now moving on, today I bought a complete MG ZT 1.8 turbo that's going to donate its engine to my Mini!!!
Old 18-06-2016, 08:10 PM   #36
jackjewell93
ECU: Emerald
Will be good to see another turbo build loads popping up. Shame about the vvc engine though.
Old 21-06-2016, 07:51 AM   #37
Went and collected my donor MG last night, i must admit i quite like it shame to kill it
Old 22-06-2016, 08:48 PM   #38
Ok... the block in the turbo donor is seized solid!!!!
So just bought another complete turbo engine!!!
Old 23-06-2016, 06:25 AM   #39
That's bananasty!
Old 23-06-2016, 07:44 AM   #40
That's bananasty!
Yep soaked the bores in diesel for 2 days, then whacked the pistons with a mallet and block of wood in anger but it wont budge!
I can still get some photos of the seats for your mate if you like?
Old 23-06-2016, 07:46 AM   #41
Yeah sure!
He's still interested.
Be worthwhile holding on to the engine too, I'd use it for a big power build because you'd need to strip it and start again anyway.
Old 23-06-2016, 09:24 AM   #42
smilerb
ECU: Will be standard
If you remove the head the crank/ liners lock up so the pistons would not move anyway however hard you wack them, I think you need special tool to clamp the liners down though the block.
Gavin
smilerb is offline   Reply With Quote
Old 23-06-2016, 09:26 AM   #43
Thanks Gavin.. I could not get it to turn over with the head still on and the plugs removed using a breaker bar.. even tried towing it in gear! lol
Old 23-06-2016, 02:14 PM   #44
Sold the MG.. its not turned out that bad, got 50 less than i paid for it but have kept the head, exhaust manifold and turbo, ECU, CD player and a seized bottom end!
Old 23-06-2016, 02:44 PM   #45
You don't mess about Chris do you! Hoping the new engine is ok now...
