Old 21-01-2015, 07:29 AM   #1
Default Raspberry Pi Laptop
first off , if you dont know what a Raspberry Pi is , its a very very cheap computer, runs a version of linux/others ,sort of a playground for big kids like me http://www.raspberrypi.org/
My daughter has just started a weekend Pi course at her local school (she is 14)
thought it would be good if we made a Pi Laptop together... not sure if it will work , only laptop we had was a small 10.1inch screen Netbook, Acer Aspire One.
First thing was to take it to bits ., not sure if it will be thick enough to hold a Pi ( its about 17mm thick ) but we can work around that later.
beers needed :
After taking it to bits i thought the best thing before spending money on a ebay display and driver was to get the keyboard to work first.
i have found a old USB keyboard, so i am just going to try and butcher that onto the 24pin connector of laptop keyboard first.
as for display , i am look at these :
http://www.ebay.co.uk/itm/10-1-Inch-...item4188bc8baf
but i notice that they are 12v ! , was hoping oneday to use the laptop battery , but thats only rated at 11.2v ..
advice on this ? 1) can you get lower power hdmi drivers ? 2) is it unrealistic of me running it on a laptop battery ?
hope to strip down main keyboard tonight , might end in failure ...
Old 21-01-2015, 07:29 AM   #2
small success on keyboard side
daughter took a logitec USB keyboard to bits , then proceeded to play with it
removed driver board
this had two connectors , 8pins and 18 pins.
i thought that the 8 pins might be similar to the 6/18 pin connector i have , but its one connector..
one cut later , i have two connectors :
so i plug in the 18 to 18 , and the 6 to the 8 ( down one end )
and plug it in !!!
it works !! .. well some letters work ,but not all , so i guess its my matrix on that keyboard is different .. anyway keys that do something when i press are :
F1,F2,F3,F4,F6,F7,F8,F9,F12,prntscreen,pause,del
1,2,3,5,7,9,-
tab,Q,P,@
caps,;,@
left arrow , right ,up and down arrows
page up
ok , these dont actually perform the correct keyboard function ..but i knew that would happen..
so advice ?what methods do i have of reverse engineering the matrix in both keyboards ?
Old 21-01-2015, 07:30 AM   #3
after working out the matrix inside the keyboard is 1)different 2) pinouts in different places i decieded i needed to know the wiring diagram of the laptop keyboard
After a night of careful thinking , and a few stellas i thought i would rip the keyboard apart to find the matrix pattern
to be fair , i think i had cut the connector as well , so it was a bit damaged at this point
i then un peeled it , as its not two seperate layers
i then traced the wires that go to the top layer ..., which i now know :
(this is looking at the top , with rubber keypads on top :
pins 1 to 26 ( pin 7 is blank and not connected )
pins 5,7,9,12,18,22,23,24 are the rows ( as i call them )
other pins are the columns of the matrix.
so i now need to map correctly to my USB driver out of my other keyboard,
I can now see why half the keys did not work.
ordered new keyboard .
now looking for a 24 pin CSI/DSI ribbon connector that i can use....cant find one yet
Old 21-01-2015, 09:01 AM   #4
Add_Gee
Add_Gee's Avatar
ECU: Rover
Looks an interesting project, I've got a Pi but haven't done much with it other than setting up a media server using xbmc.
Old 21-01-2015, 09:22 AM   #5
found me a connector and ordered , should have all i need to get keyboard working now..
well apart from key mapping at a OS level .. next thing
Old 22-01-2015, 03:58 PM   #6
daveyjones
Might be fun with an arduino too http://www.ebay.co.uk/itm/UNO-R3-Ard...item2a48169f94
daveyjones is offline   Reply With Quote
