Old 27-03-2017, 10:41 AM   #46
fatmat25
fatmat25's Avatar
ECU: standard for the mo
this is cool as f*/k love the look, defo loving the steelies though
fatmat25 is offline   Reply With Quote
Old 28-03-2017, 06:04 PM   #47
mr-cooper
mr-cooper's Avatar
ECU: Pgmfi; MS
today a little trip on the german autobahn
3000rpm = 125kph
4000rpm = chilly 170kph
yeah!
Water temp 91-94degrees c
Oli around 100
Inlet 30-35 degrees at 20C temp outside
Pretty okay all
__________________________________________
my homepage: www.custom-minis.de
mr-cooper is offline   Reply With Quote
Old 02-04-2017, 06:51 AM   #48
mr-cooper
mr-cooper's Avatar
ECU: Pgmfi; MS
just a little Video
cheers
Old 02-04-2017, 08:58 AM   #49
Where's the vid Olly? not showing for me, but could be because of my works computer or fire wall settings.
Old 30-04-2017, 10:15 AM   #50
mr-cooper
mr-cooper's Avatar
ECU: Pgmfi; MS
https://youtu.be/tQPWe3zwtaI
Just another little video Have fun
Old 30-04-2017, 02:22 PM   #51
Awesome vid, the roads in Germany always look perfectly smooth!
Car seems to be running well, have you had it on a rolling road yet? Also, did you go for the electronic boost solenoid version from KMaps?
Old 30-04-2017, 06:33 PM   #52
gouldy847
ECU: MEMS I THINK
Where abouts in Germany are you pal?
Old 01-05-2017, 07:30 AM   #53
mr-cooper
mr-cooper's Avatar
ECU: Pgmfi; MS
Hey,
yes i got the mapped ECU from K-maps...
The Setup with the semi slicks works really well, even without a lsd it gets the power well on the ground... I will try to increase boost level a little bit (need to try out, where the "map" ends, and create a error-code, so i know at what boost the max is)
The roads here aren´t perfectly smooth!!! It depends where you drive, but the suspension is working fine.
Yesterday on the german autobahn, had some fun... :P
Suspension/Brake balance setup is on the list for some fine tuning. I need to cut out some brake pressure on the rear brake (just turning the valve)
I am located near Düsseldorf
cheers
