Old 13-12-2014, 08:26 PM   #16
mr-cooper
mr-cooper's Avatar
ECU: Pgmfi; MS
Hey there,
some more progress:
Made a pair of Hilos.
Assembling the powder coated frames
first time on the 14" wheels
Build a flare tool for the arches...
Muuuch better!!
Rear arches, same procedere
i love the look
cheers
__________________________________________
my homepage: www.custom-minis.de
mr-cooper is offline   Reply With Quote
Old 13-12-2014, 08:30 PM   #17
apbellamy
apbellamy's Avatar
ECU: SC Typhoon
If Basil Faulty had this car, his life would have been much less stressful...
Old 20-12-2014, 11:12 AM   #18
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Wow loving this build. Nice to see summat different
Old 28-12-2014, 08:00 AM   #19
mr-cooper
mr-cooper's Avatar
ECU: Pgmfi; MS
Hey there,
some more progress:
Drivetrain ready for installation.
Rear subframe with stock antirollbar and new coilsprings
I will fabricate a longer shaft between knuckle and Hilo.
You can spot the shocks-tower, made from some 63,5mm exhaust tube
What a beauty
Old 28-12-2014, 09:16 AM   #20
Add_Gee
Add_Gee's Avatar
ECU: Rover
Really love the look of this
only question... is that front shock tower only mounted to the inner wing?
Old 28-12-2014, 09:44 AM   #21
Look's stunning Ollie!
Old 28-12-2014, 09:45 AM   #22
apbellamy
apbellamy's Avatar
ECU: SC Typhoon
Old 28-12-2014, 03:51 PM   #23
mr-cooper
mr-cooper's Avatar
ECU: Pgmfi; MS
@add gee: it is welded to the double layered inner wing part, that supports the top rubber (bump stop). I could make up a bar between both towers...
But first i need to solve the master-cylinder mounting, as it doesnīt work that way, because the throttle body is hiting it.
cheers
Old 05-01-2015, 09:02 PM   #24
mr-cooper
mr-cooper's Avatar
ECU: Pgmfi; MS
Happy new year
The Master cylinder + Servo has a new place with a custom linkage.
I ordered a radiator and started the plumbing. Expansion tank + heater is next on the list.
Shifting linkage from a Honda Vtec.
I wondered what a tiny tiny throttle body was fitted..
...a Honda D-Series Throttle body with 56mm was my first choice.
Made a adapter on the mill.
I have to get the throttle sensor to the honda item. Just some small machining on the lathe/mill...
Right now I am creating a disc brake for the rear.
The MGF brake calipers didnīt fit, i found a pair of type R Honda rear brake calipers... i give them a chance!
cheers
Old 09-01-2015, 02:22 AM   #25
Freebies
Freebies's Avatar
CC: D15B
ECU: MTD Frame, not MTB
Very impressed! Nice ride
Freebies is offline   Reply With Quote
Old 24-01-2015, 07:57 PM   #26
mr-cooper
mr-cooper's Avatar
ECU: Pgmfi; MS
Hey,
some more progress on the Inno i4
Made up a flange/plate for the intank fuel pump.
Welded a tiny catch-tank underneath the tank.
Some machining on some superhard-alloy for 2 disc-brake-caliper-mountingplates.
Machined the drive flange to the correct dimensions.
Some shrinkle paint on the mounting plates.
MGF rear discs machined to match the back of the the hub.
Honda Type R- Rear callipers.
There it is, a disc brake conversion on an ADO16
Installed the 14" Steel wheel with the 185/55r14 Rubber.
Thanks for looking
cheers
Old 25-01-2015, 01:04 AM   #27
Freebies
Freebies's Avatar
CC: D15B
I really like your work.
Old 28-01-2015, 06:37 PM   #28
mr-cooper
mr-cooper's Avatar
ECU: Pgmfi; MS
Thank you guys!
The first Time on 4 matching wheels.
Swapped the steering wheels (V8 London Taxi/ Inno i4) so the Hellebore 3 Spoke wheel is in the right brand car.
The first MGF Seat was bolted into the Inno. The red-leather is kind of matching the old stuff.
Yeah, wiring loom! The plan is to keep the original electric from the Inno, just add the Engine loom and connect the gauges, OBD2 Socket, hot wires etc.
cheers
Old 29-01-2015, 08:54 AM   #29
Add_Gee
Add_Gee's Avatar
ECU: Rover
That looks sooooo good, no-one will suspect what's under the bonnet
Old 29-01-2015, 05:39 PM   #30
mr-cooper
mr-cooper's Avatar
ECU: Pgmfi; MS
Thanx Add_Gee
Is there somebody in the UK who has a spare Exhaust Manifold whith a Turbocharger for my K-Series?
:P
I extended the Throttleshaft to bolt on the TPS from the MGF.
I made up an adapter:
It is 15° movable to finetune it to the right position.
The Speedo was hiting 90km/h while standing still.. WOW
The little springs and wires were broken...
..got 2 Spare-Speedos from the uk.
cheers
