Old 20-11-2014, 07:49 PM   #1
mr-cooper
mr-cooper's Avatar
ECU: Pgmfi; MS
Default Innocenti i4 (Austin 1100/1300) VVC
Hey there,
it is not, that i got bored, but a customer had a great 1964 Innocenti i4 in his garage... okay, now its mine
Okay, it is bone stock, original non modified... untill now!
Ooookay here we go:
Got rid of the old lump.
I wanted to bolt in the whole mgf package...
First of all, changing vom RWD to FWD
Not even close...
To prevent some headaches, i took my frame rig and startet over with some K-Series Frame Fragments.
That works better!
Frame is aligned and bolted to the upper brackets. It got towers for my springs and the Gearbox is already mounted.
Okay, the 13" ATS 7" wide wheel is not an option.
I ordered some steel wheels in 5,5"x14" with pdc 4x100 and ET40.
They will fit straight forward under the wings.
The flanges are rebored from 4x 95,25 to 4x100.
The whole action took 2 days until now.
More to come.
Cheers Olli
__________________________________________
my homepage: www.custom-minis.de
mr-cooper is offline   Reply With Quote
Old 20-11-2014, 08:56 PM   #2
bobjonah
bobjonah's Avatar
VERY Nice - I'll be watching this
Bob Jonah
Old 20-11-2014, 08:57 PM   #3
WOW! That's some good skills you have there Olli.
Old 20-11-2014, 09:03 PM   #4
apbellamy
apbellamy's Avatar
ECU: SC Typhoon
nice
Old 26-11-2014, 07:06 PM   #5
mr-cooper
mr-cooper's Avatar
ECU: Pgmfi; MS
Thanks guys,
more progress, more pictures:
On its own feets (MGF spare Wheels)
Steering collumn
Brake drum ready to be reduced in weight and to become a flange for the disc brake
Re fitting the panel.
Dropped the subframe for the finishing.
Finished (but waiting for the ordered 4mm round plate to be welded in to the 2. dome.)
Sandblasting/powder coating plus refreshing the supsension parts.
cheers olli
Old 26-11-2014, 07:18 PM   #6
andyfkettle
andyfkettle's Avatar
Love the use of brake drum into a flange. Great idea and some nice fabrication.
Old 26-11-2014, 07:24 PM   #7
mr-cooper
mr-cooper's Avatar
ECU: Pgmfi; MS
@ andy, somehow I needed to swap to discbrake on the rear, and as i saw that the drums are the flanges (with bearing) there was only one way.
The Metro flanges didn´t fit, so i had to machine something.
I need to install some shockabsorbers. That will be fun: no mountings on the car and no mounts on the rear radius arms, not a real big deal, but need to insert tubes where the shocks will fit inside. would be the fastest way to get around this.
Drilling and taping the rear radius arm axle to get a shock mount is the route i will choose.
cheers
cheers
Old 27-11-2014, 12:52 AM   #8
Got to admire your sence of. Humer,
Hope you make that nasty car Into something good,?
I'm sure you will,
Old 27-11-2014, 07:59 AM   #9
gimenofl
gimenofl's Avatar
CC: 1380
ECU: Typhoon Specialist Co.
Mr. Cooper,
You had that fantastic thread on a Van, is it finished, can you show us more?
Thanks,
Lluís
Old 27-11-2014, 08:30 PM   #10
mr-cooper
mr-cooper's Avatar
ECU: Pgmfi; MS
@ Lluís: which (of the) van(s) do you mean?
cheers
Old 28-11-2014, 07:22 AM   #11
cedric998
i think he means this one ...
http://www.custom-minis.de/custom-mi...allye_Van.html
brgds
chris
Old 29-11-2014, 09:31 AM   #12
mr-cooper
mr-cooper's Avatar
ECU: Pgmfi; MS
Oh, yes okay, i Need to Update the Thread!
Old 29-11-2014, 09:52 AM   #13
Andy_S
Andy_S's Avatar
ECU: Megasquirt ... kinda
Love this build
Old 29-11-2014, 11:43 AM   #14
7xsteve
Actually it looks great on the MGF spares wheels! I would be tempted to fit them along with some lower profile tyres.
7xsteve is offline   Reply With Quote
Old 29-11-2014, 04:19 PM   #15
gimenofl
gimenofl's Avatar
CC: 1380
Yes, yes, more on the build(s)
