Old 08-11-2014, 09:02 PM   #1
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Default Mk2 Escort
Here's what I've been playing with lately
Managed about 30 miles with several stops for overheating, removing thermostat, topping up water etc before giving up n getting it brought home
Just about fits in the garage with the Mini
In the process of sorting the rust around the front end then the engine can go in. Going from 1100 to high compression 1640. Nothing to lairy for now
Bought some alloys but they need a bit of work so had a go at polishing. Pleased how my first effort came out. Needless to say they're not staying yellow!
That's all for now...
Old 08-11-2014, 10:15 PM   #2
Looking good, how did you go about the polishing?
Old 08-11-2014, 10:49 PM   #3
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Just bought an alloy polishing kit off eBay that fits on the drill. I used emery cloth to get the worst of it off, wet n dry and then the kit. I got 2 compounds and 3 polishing wheels
Old 15-11-2014, 03:33 PM   #4
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Default Mk2 Escort
Had a busy week on it. Swapped the square headlights for round...
Fitted the seats. They're Cobra buckets covered in leather and blue suede...
And then this morning had a wrestling match getting the engine in...
Old 11-12-2014, 05:49 PM   #5
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Default Mk2 Escort
Got a set of zx6r bike carbs with manifold to go on. Need to sort some vacuum fittings for it for the dizzy though...
Fitted the alloy rad and Davies Craig fan. Also found out why it had overheated on the way home. The water pump was chocka full of limescale so not much pumping going on...
Carbs just squeeze in but not much room for filters. Also sorted the wiring for the fan and for the bike fuel pump which I've mounted on the rear chassis rail...
Took the fuel tank out as there was some rot in the well...
Welded and kurust applied...
Seam sealed and painted. I've since sprayed loads of Dinitrol in here to keep it safe...
Wired the headlights in too and fitted some smd sidelights. They're almost as bright as the headlights!
That's all for now I think...
Old 11-12-2014, 08:46 PM   #6
cherrybomb
CC: 1598
ECU: dta
Nice progress fella
cherrybomb is offline   Reply With Quote
Old 11-12-2014, 11:21 PM   #7
All good john,
I supose you have to have a good snece of humer with a mini sat there
Old 08-07-2016, 10:19 PM   #8
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Default Mk2 Escort
Hmmm lost a fair bit on here but cars all good. Moved house n had single garage extended into a double so plenty of room for both toys now
Gradually tarting it up a bit...
Old 08-10-2016, 06:42 PM   #9
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Default Mk2 Escort
Got the garage pretty much all set up. Put in a consumer unit, 6 double sockets and 8 5foot led strip lights.
Been faffing with the car too. Fitted zx6r bike carbs which are been raspberry to get right, a Tran-x LSD and put some tyres on my Revolutions
Sent from my D5503 using Tapatalk
Old 02-01-2018, 11:28 PM   #10
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Default Mk2 Escort
Well since i last posted Ive done a few bits to the car. First off was to move the master cylinder into the cabin. Used the Wilwood 1 master cylinder that i originally had on the Mini
This was so i had plenty of room to fit these twin 40 Dellortos
Old 02-01-2018, 11:30 PM   #11
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Also got some 7 Revolutions for the back wheels
Old 02-01-2018, 11:33 PM   #12
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
All sitting pretty. Escort is on the road but now Ive (hopefully) sorted the Minis electrical problems then that will be getting on the road come springtime
Old 03-01-2018, 02:00 AM   #13
having 2 classic cars is like haveing a afiar with 2 bumpy jumpers, (woman)
Old 04-01-2018, 08:07 AM   #14
Kam
Kam's Avatar
Excellent work
How low is that escort front end? Might just be the picture but its looks like you'll be scraping the roadkill up
Old 06-01-2018, 12:04 PM   #15
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
It makes the Mini look like a monster truck on that pic. It is pretty low to be fair. Got coilovers on the front and 2 lowering blocks on the rear. Spoiler makes it look lower I think .
