Old 02-02-2013, 08:18 PM   #16
steve s
Removed a bit more rust this afternoon, Thankfully this is the worst side,
steve s is offline   Reply With Quote
Old 09-02-2013, 09:58 PM   #17
steve s
Finished nearside B post today, I'll be able to use jacking point now, Put front wheel arch on and started welding rear trailing arm mountings, I will be glad when the weather warms up a bit,
Steve,
Old 12-02-2013, 12:50 PM   #18
big_jim
big_jim's Avatar
Great work you are doing there mate. Look forward to seeing this at some events.
Jim
big_jim is offline   Reply With Quote
Old 05-03-2013, 10:10 PM   #19
steve s
Almost finished welding the nearside today, I have cut out all the rot and welded new metal in, Sandblasted remaining surface rust and treated areas with jenolite to neutralize any rust i may have missed,
Old 01-04-2013, 09:49 PM   #20
steve s
Finished welding nearside, Just need a bit of filler in the cab door and a coat of primer, Then start on the other side,
Steve.
Old 02-04-2013, 02:17 PM   #21
sure you no , as works good, you working outside? im embarest to say how many times ive put primer on new work the coverd it up to do other side, when i went back the primer had absorbed water and i was back to brown,, only way i could stop it was buy painting it with waterproof pain[just paint] would be a shame even for a v.w ,lol
Old 02-04-2013, 07:55 PM   #22
steve s
It'll not be in primer long Shaun, I know it is porous, so i will put some top coat on if things take longer than i would like, The other side isn't as bad, No big holes and i have already repaired the other sliding door, Hopefully the weather is improving as well,
Steve.
Old 17-06-2013, 08:57 PM   #23
steve s
Not done any work on the camper for two months, Been really busy with work, Had a few hours today, So fitted a new front panel, been collecting bits thou, So once it's painted it should go back together quite quickly,
Steve.
Old 19-06-2013, 09:55 PM   #24
steve s
Removed the rest of the glass today, realy happy with the condition of the window frames, just three holes to weld up on the windscreen aperture, the tailgate is off a later van, So that is in good nick, The cab door frames are surprisingly rust free,
Old 02-10-2013, 11:26 AM   #25
steve s
Passed a big milestone, Finished the welding , I have put some topcoat on to protect the body while i strip and prep the rest of the bus, It feels like it has taken forever to get to this stage, I am sure it will be worth it when its done. whenever that is, Heres a pic in the dark,
Steve.
Old 11-10-2013, 05:40 PM   #26
DVO
DVO's Avatar
ECU: Chipped
Looks good, nice detail: Mercedes wheelcover
Old 30-11-2013, 11:31 PM   #27
steve s
Put the windows back in today and started putting door fittings in, The roof is in bits now, i am respraying the roof panels and re lining them with veltrim, so the fiberglass bits will all be painted together later,
Steve.
Old 01-12-2013, 08:43 AM   #28
apbellamy
apbellamy's Avatar
ECU: SC Typhoon
That looks tidy
Old 01-12-2013, 11:08 AM   #29
PaulW
PaulW's Avatar
ECU: Megasquirt MX5 Pnp
looks great Steve, i might have a trip over to see it myself.
I bet your lass is over the moon at how the drive turned out
Paul
Old 01-12-2013, 06:33 PM   #30
steve s
Your welcome over anytime Paul, Just bring a bucket with you and a scrubbing brush of course,
