Old 03-01-2018, 09:36 PM   #256
joakwin
CC: 1.6
ECU: Bone stock
yes they will,, deffo,, 175,50,13 is a hard rubber like wooden block,
is there any more soft ballons tyres ?
I was looking at maybe a 175/60/13 and or a 185/60/13
I know a 185 wouldn't fit with a stock subframe in the back but I have a mini tec beam
Old 04-01-2018, 10:36 AM   #257
i think your in the gold ,, nice comfrtable hi,way crueser
Old 08-01-2018, 10:05 PM   #258
joakwin
CC: 1.6
ECU: Bone stock
just got to get the money together to buy the wheel studs and lug nuts and tires
those wheels I was looking at are made for 1/2inch wheel studs, a ton bigger then the 3/8's wheel studs the mini has right now
I don't think the wheel stud flanges on minis can support being drilled out that far
I also have a set of 13x5 minilite wheels, I plan to upgrade to a 7/16 stud, and then the lug nuts for that size is a friction of the price
I was looking here in the states, and they want about $8 USD a lug nut for a 3/8's lug nut for those minilite wheels, I can get the 7/16 lug nut in a 5 pack for about $15 plus shipping
so I'm going to order lug nuts and studs next pay day
Old 09-01-2018, 12:22 AM   #259
joakwin
CC: 1.6
ECU: Bone stock
I got a intake tube for the car now
intake by joaquinn lopez, on Flickr
Old 13-01-2018, 12:33 AM   #260
joakwin
CC: 1.6
ECU: Bone stock
I got new 7/16 wheel studs in the mail today
I only ordered wheel studs for the front of the car, just to check it out
lug nuts will be in Tuesday
plan to install those tonight
Old 13-01-2018, 07:35 PM   #261
joakwin
CC: 1.6
ECU: Bone stock
716 studs by joaquinn lopez, on Flickr
one hub has 7/16 studs installed in it
plan to do the work on the other side later in the afternoon
Old 23-01-2018, 11:47 PM   #262
joakwin
CC: 1.6
ECU: Bone stock
coilover bar by joaquinn lopez, on Flickr
coil over tower support bar that i made, connects the two coilover towers together
its made out of 3/4 120wall dom tube
Old 03-02-2018, 07:01 AM   #263
joakwin
CC: 1.6
ECU: Bone stock
rear brakes 2 by joaquinn lopez, on Flickr
i moved the location of the coilover so that i could move the location of the caliper
Old 08-02-2018, 05:09 AM   #264
joakwin
CC: 1.6
ECU: Bone stock
rear disc brake 3 by joaquinn lopez, on Flickr
finally happy with the mock up mounting bracket
Old 13-02-2018, 10:34 PM   #265
joakwin
CC: 1.6
ECU: Bone stock
reear brake caliper pad fitment by joaquinn lopez, on Flickr
picked up some t6160 aluminum plate today
Old 14-02-2018, 01:04 AM   #266
joakwin
CC: 1.6
ECU: Bone stock
rear brake 5 by joaquinn lopez, on Flickr
Old 16-02-2018, 06:03 PM   #267
joakwin
CC: 1.6
ECU: Bone stock
Untitled by joaquinn lopez, on Flickr
one bracket has been cut out
plan to get the 2nd bracket cut out this weekend
and paint the pair gloss black
Old 17-02-2018, 09:47 AM   #268
Can you get a better radius in the 3 areas that look to be almost right angles? That''s the most likely place for a fatigue crack to propagate from. In the previous pic where the shape is penned onto the material the radius in each case looks much more generous.
Old 17-02-2018, 05:22 PM   #269
joakwin
CC: 1.6
ECU: Bone stock
yeah i see what you mean, its a good idea
i will work it into the next one i cut out.... at the same time, its also 1/2 inch thick material
Old 18-02-2018, 04:09 AM   #270
joakwin
CC: 1.6
ECU: Bone stock
rear brake bracket by joaquinn lopez, on Flickr
here's my 2nd bracket, i made a few changes
i still need to clean it up, its a super ruff cut right now
im probably going to pick up some more 1/2 inch t6160 aluminum on Monday, and cut out another bracket so i wont have to run that 1st one
