Old 04-09-2017, 07:58 AM   #91
geachy87
geachy87's Avatar
CC: 1.8t
ECU: Kmaps
Have you got any pictures of what you did to move the engine back? Pretty sure I'll end up going turbo at some point so might as well move it all back now
Old 05-09-2017, 09:18 AM   #92
Readie
Readie's Avatar
ECU: KMAPS TURBO
Engine side I just moved the mount back, drilled the arm for the bolts to mount it in its new position and then extended the bracket for the steady.
Gearbox side i just moved the mount back and bolted it into a hole that was already on the arm.
Other than that i did alter the bulkhead for the inlet manifold and took a piece out of the back of the subframe to clear the diff. Just make sure that you have the driveshafts in when you move the engine back to make sure they clear as mine are very close.
Readie is offline   Reply With Quote
Old 05-09-2017, 09:41 AM   #93
geachy87
geachy87's Avatar
CC: 1.8t
ECU: Kmaps
Thanks, it was the diff to subframe bit I wasn't sure about, I see you're using the mini steering rack, I'm using the metro one mounted to the subframe so not sure if I can cut any of the subframe away, I'll need to have a look and see
Old 24-09-2017, 06:52 PM   #94
geachy87
geachy87's Avatar
CC: 1.8t
ECU: Kmaps
Where did you get your weld fittings from to make the manifold? Is it short or long radius elbows you used?
Old 25-09-2017, 08:53 AM   #95
Readie
Readie's Avatar
ECU: KMAPS TURBO
http://www.fhbrundle.co.uk/products/...8_3mm_O_D_Tube
If your making a manifold though its worth doing something abit more efficient than the log manifold like I am currently using.
This is what i am working on at the moment.
IMG_20170921_160123 by Peter Read, on Flickr
Old 25-09-2017, 09:39 AM   #96
geachy87
geachy87's Avatar
CC: 1.8t
ECU: Kmaps
That looks pretty good, anymore pictures of it?
