Old 21-05-2012, 06:45 AM   #16
PaulW
PaulW's Avatar
ECU: Megasquirt MX5 Pnp
Could you post the link up please? I'm curious as well
Paul
Old 21-05-2012, 06:59 AM   #17
blue blood
Originally Posted by dig-mini View Post
I'm a builder by trade and we use this all the time water based glue rolled on with a paint roller and then roll the rubber out in one piece no joints. They life of 50 year at 400 quid it got to be cheaper than felt and it will take you about 3 hours to do.
pm'd my link what I use
Craig
Me and my brother built his timber framed house and used the rubber roof. It turned out really well but is heavy to manoeuvre when first delivered but it is fine when rolled out on a roof.
Regards Blue
blue blood is offline   Reply With Quote
Old 23-05-2012, 09:37 PM   #18
bhphunter
bhphunter's Avatar
Heres the rubber roof link for those that wanted it http://www.rubba-seal.co.uk/order+form
cheers
build diary
Old 23-05-2012, 09:57 PM   #19
Looks similar to the Sarnafil roofing I use, much more DIY friendly though.
Good stuff!
Old 04-08-2012, 11:23 PM   #20
bhphunter
bhphunter's Avatar
The bananasty weather we have had in July (not a single dry day) has really slowed progress down on my garage build but been plodding along slowly between showers and under a tarp : (
Main structure is now complete, clad and painted, roof is on and today I got the underfelt on. Windows are in, side door is hung and ive started building the the front doors. Bit time consuming these as there is 12 mortice and tenon joints and each one is drilled for glued dowels.
Anyway some pics...
build diary
Old 05-08-2012, 05:04 PM   #21
Marcus Nordblom
Marcus Nordblom's Avatar
ECU: 40mm mikuni rs
Man cave
Old 13-01-2014, 11:40 AM   #22
bhphunter
bhphunter's Avatar
Well the garage has been finished for a while now but got filled so quickly with junk that the mini hasnt ever made it in : (
Starting clearing it out at the weekend and to my horror found a damp patch at the bottom of one on the platerboard sheets, which I removed to find the insulation was wet.
Turns out the water running off the roof has been splashing up from the ground and into a small void at the bottom of the external cladding, soaking the inside of the cladding and the insulation.
So this week will see me strip out the entire inside of the garage, shelves, cabinets tools, elecrical conduit, big bolted to walls work bench etc then remove all the platerboard and insulation before leaving it to dry out. I cant explain how grapesed off I am at the moment - mini should have been coming here this week but now its going to be another long delay
build diary
Old 13-01-2014, 12:29 PM   #23
filski
to top it off you could of got an inspection hole in the ground but this looks lush either way
Old 14-01-2014, 12:26 AM   #24
bhphunter
bhphunter's Avatar
Stripped the internal plaster board walls off tonight and worked out the moisture has got in between some of the tongue and groove joints in the cladding.
Not sure how this can be as they all seem the same, some are soaking, some are damp but most are fine
Will post pics tomorrow if anyone gives a melons...
build diary
Old 14-01-2014, 08:23 AM   #25
Default Garage Build
You could try running a line of caulk down the joints, only problem is, it would have to dry before it could get wet, other option would be to use silicone, but it isn't over paintable.
Just went to have a look at the pics of the build and noticed there isn't a breathable membrane between the cladding and stud work, that would certainly help, but would mean stripping back all of the cladding.
A final option would be to replace the cladding for a shiplap cladding, this would form a drip at every join and prevent the joints getting wet.
Old 14-01-2014, 08:58 AM   #26
bhphunter
bhphunter's Avatar
I was thinking brown frame sealant would maybe the way to go but there is about 300m of joins over the whole garage - feck!
You'll see from previous photos that I installed a plastic sheeting over the stud work before putting a spacer strip of wood down each vertical frame strut and then the cladding ontop of that - idea being there would be a breathing space between the cladding and the frame so I could then insulate and platerboard.
The plastic sheeting wasnt the right stuff as it didnt stay tight enough with the bad weather there was while building it. I removed it and filled the void with insulation directly between cladding and plasterboard. Hindsight is a wonderful thing.
Im going to let it dry out, then work out best way to stop the moisture getting through, probably seal all the tongue and grooves?
build diary
Old 14-01-2014, 09:06 AM   #27
If you seal the joints, I would personally use white or an off white decorators caulk as it would stain up pretty much the same colour, brown caulk will be darker.
Old 14-01-2014, 09:16 AM   #28
Marcus Nordblom
ECU: 40mm mikuni rs
how about downspouts?
Old 14-01-2014, 09:34 AM   #29
bhphunter
bhphunter's Avatar
Was just concerned that caulk would be flexible enough to shrink and expand with the wood during dry and wet spells? Would match better once painted though : )
Ive added gutters now aswell but not sure if it will make much difference to this problem as the side that is worse gets a sideways beating from the weather.
cheers for the comments, keep them coming...
build diary
Old 14-01-2014, 09:37 AM   #30
Marcus Nordblom
ECU: 40mm mikuni rs
fold down tarp when the weather gets rough
