Old 11-11-2011, 10:21 PM   #16
chabbly vvc
chabbly vvc's Avatar
Snapped these up earlier in the week...
Im missing the 4 bottom brackets like the ones in the top of this pic...
Has anyone got a full size template of these so i can make some?
cheers charly
Old 27-11-2011, 08:56 PM   #17
chabbly vvc
Got some more work done 2 day finished off the gear linkage and made it water proof...
Modified bulk head so more clearance for inlet manifold...
Old 27-11-2011, 11:25 PM   #18
Why have you chosen to run the gear linkage this way?
I have just cut mine to the required length under the tunnel, as normal....
Old 28-11-2011, 10:03 PM   #19
chabbly vvc
I could'nt get the linkage 2 clear the rear lowwer gearbox mount on the allspeed frame. Looked it up on the 16v mini shop's build and other peoples builds on here using the allspeed frame and they all did it like this. I just added the steering rack gators so i dont get wet feet lol
The metro/watson frame has the 3 holes 2 mount the gear linkage on at the back of the frame and no lowwer gearbox mount im rite in thinking?
Old 29-11-2011, 04:21 PM   #20
I'm using the Watsons frame. Also the PG1 gearbox.
It seems a lot simpler to adapt as it's similar to remote Mini one, just beefier. All fits under the car next to exhaust.
Old 04-12-2011, 09:35 PM   #21
chabbly vvc
Rebuilt my top arms 2day and fitted them 2 the allspeed frame... did the bolts up nice and tight and its pulled the frame 2geather a fair bit where the top arm sits and bent the new end caps (the one with the 2 10mm bolts in). Ive used new washers and bolts from a minisport repair kit and put it all back 2geather the same way it came off the standard mini frame. Is this ok for the frame 2 be pulled in? Is my frame not made right? Or have i done somthing wrong?
Old 04-12-2011, 09:49 PM   #22
cherrybomb
CC: 1598
ECU: dta
Hi, if it helps I seem to remember with my Allspeed frame that you use two of the 'fat' spacer washers one each side of the top arm, this fills the gap.....my frame is a small block vaux but would imagine the top arm arrangements are the same. Andrew
cherrybomb is offline   Reply With Quote
Old 04-12-2011, 10:40 PM   #23
chabbly vvc
I did a quick search on here and seen that some people used fat washers on either side. I will try this 2moro and see if it makes it any betta...
If it worked 4 you hopefully it will sort mine out cheers andrew.
Old 07-12-2011, 09:55 PM   #24
chabbly vvc
Got my top arms all sorted now used the thicker washers either side and now spot on.
Finally got my minisport rose jointed bottom arms and tie rod arms though the post yesterday, Drilled the 10mm allspeed frame holes out 2 12.5mm Got some new bolts and made up same spacers for the bottom arm rose joints. So thats that all sorted and save me .
Fitted KAD steering rack reducers and new boots 2 the steering rack so the 4 pot callipers wont thouch the tie rod arms on full lock.
Now all thats sorted i can work out my drive shaft lenghts .
Got a remote oil filter kit on the way in the post so when that comes i will have a pop at the wiring and try get her running
Will take some more pictures on the weekend because i know thats what everyone really wants 2 see lol Just keep 4 getting 2 take any when im working.
Old 08-12-2011, 06:25 PM   #25
matt
matt's Avatar
ECU: Mems 3 Z&F
Defo get some pics up. Now many about with the Allspeed frame
Rover no show and all go!!!!!
Old 15-12-2011, 10:05 PM   #26
chabbly vvc
Will deffs be posting an update after this weekend gunna try have a hole day working on it sunday.
Found a few pics from USC with the standard 1275 engine in lol
Hopefully nextd year at santa pod my time will be a little bit quicker than this lol
Old 16-12-2011, 04:20 PM   #27
I am presuming this is the A series....
Me and my mate ran at York last year. I got 19.4 and he got a 18.7. His is a carb Cooper mine is and SPi Sprite.
I'm hoping to beat these with the K series.
Old 17-12-2011, 02:15 PM   #28
chabbly vvc
And i thought the wiring was gunna be ok ahhhhhhhhh my brains fried non of the wires on my mpi loom are the same colours as the vvc loom. I cant find anywhere that will let me dwn load a rave cd... stuck stuck stuck
Old 17-12-2011, 03:05 PM   #29
cooper_mark
cooper_mark's Avatar
u have pm
my beast
Old 18-12-2011, 11:55 AM   #30
matt
matt's Avatar
ECU: Mems 3 Z&F
Don't go by wire colors go by pin outs as rover changed the colors all the time.
With the engine loom look for things like battery light. Have a look at the alternator note the color and it should go up to the grey plug. Then eliminate them that way.
Then just find a pin out of your bulkhead grey plug and your laughing
