Old 07-11-2010, 07:56 PM   #1
Default What to paint your Subframe With
OK, doing some serious grinder action / welding on my home made subframe.
Question is what should I paint it with once finished?
I intend to get it blasted or try and blast it myself. Then I guess Etch Primer? And then some chassis black?
Recomendations / advice on paint etc please
Old 07-11-2010, 08:03 PM   #2
Coupe
Coupe's Avatar
Por15 is very very good stuff - comes highly recommended.
Saloon K Series conversion sold
Clubby Estate K Series conversion sold
Coupe is offline   Reply With Quote
Old 07-11-2010, 08:06 PM   #3
Does it come in aerosol or is it just a brush on job. Etch primer first??
Old 07-11-2010, 08:16 PM   #4
brush on, if you sprayed it you would die, im sure its more toxic/dangerous than even 2-pack paint, required special prep google and read the datasheet
Old 07-11-2010, 08:35 PM   #5
philster
philster's Avatar
ECU: Megajolt + bikecarbs
I'm planning on using POR15 for the frame (both front and back) , the floor and sills and any other metalwork you can't see (ie under the carpets etc)
philster is offline   Reply With Quote
Old 07-11-2010, 08:43 PM   #6
cooper_mark
cooper_mark's Avatar
etch primer X2 coats then a couple of coats of primer then chassis black
my beast
Old 07-11-2010, 08:53 PM   #7
John Auty
its bad i know but i usually use red oxide primer and use hammerite, nice and cheap
John Auty is offline   Reply With Quote
Old 08-11-2010, 10:35 AM   #8
Cheers for the advice. POR 15 maybe then, but sounds toxic. Will look it up.
If there are any other alternatives that people have used, let me know. Ta
Old 08-11-2010, 10:56 AM   #9
POR15, been doing some research into this stuff, you only need etch primer on new metal really, you can paint the POR15 straight onto rust if you wanted.
As far as I can tell, this stuff really kicks ass, I mean really kicks ass, it has a 30 year guarentee!
You have to top coat anything that is in sunlight as it doesn't seem to be UV stabilized.
Shall be doing the whole 3 step process then a coat of chassis black on the entire underside of mine when I get to that stage, only going to do the 3 stage plus chassis black because I want to be certain the underside of my baby is bullet proof to the elements.
Rust Bullet was supposed to be an alternative, but I've seen nothing but bad reviews about it.
Old 08-11-2010, 10:57 AM   #10
Purtsi
Purtsi's Avatar
powdercoat it. end of discussion
I have a cunning plan...
Old 08-11-2010, 11:16 AM   #11
Yeah, just read up on it as well. I think finish the frame, have it blasted. Get it home, a quick degrease and then just brush paint POR 15. Dont think there will be much exposure to sunlight. Better check the cost of this stuff though.
Old 08-11-2010, 11:37 AM   #12
www.frost.co.uk
Old 08-11-2010, 02:52 PM   #13
nerdymind
nerdymind's Avatar
CC: B16
guys am about to change my floor panel...a complete one...i need to know after i attach the new panels...is there something i put on the panels from the inside or outside?
thnx
Thank you
Ayman
nerdymind is offline   Reply With Quote
Old 08-11-2010, 02:57 PM   #14
thnx
Yep - Paint and carpets on the inside if you want to be comfortable.
Old 08-11-2010, 03:15 PM   #15
LOL!
make sure you put something on any welds. just primer will do inside.
as for the underside, you'll want to underseal it with POR15 or similar, as I said earlier, you'll need to etch primer new metal if using POR15.
