Old 09-09-2018, 01:00 PM   #1
Doodling
Default Breather line id help
Could anyone help me.
Where does pipe 1 and 2 go to or come from. Cheers
Doodling is offline   Reply With Quote
Old 10-09-2018, 12:52 AM   #2
250ptm
250ptm's Avatar
ECU: odb1
line 1 is part of the old engine breather system. line 2 part of the charcoal can system. I capped the one on the throttle body. removed line 1 completely and added a filter at the rocker cover. Your FiTV water line has a different routing, mine now runs from the water outlet on the inlet manifold, which used to run to the IACV. I deleted the water line to the IACV completely. I don't need it al all. Been like this for 7 years without issues.
It only took me 3 years to reach 100 posts and become a senior member!
250ptm is offline   Reply With Quote
Old 11-09-2018, 02:36 AM   #3
joltfreak
joltfreak's Avatar
Subframe: MTB
ECU: Standard-ish
Did the same with mine
joltfreak is offline   Reply With Quote
Old 11-09-2018, 05:28 AM   #4
Yep, done the same with 2 recently.
I’ve left 1 as pictured for now but plan to add a catch can for that one.
Old 14-09-2018, 07:10 AM   #5
250ptm
250ptm's Avatar
ECU: odb1
Haz, Line 1 does not need a catch can. it was functioning as the INLET for the engine breather system.
Old 15-09-2018, 05:32 PM   #6
joakwin
ECU: Bone stock
I left the emissions hooked up on line 2 and still have the charcoal can hooked up and tan lines to the fuel tank for it, but I’m also running a stock del sol tank in my car so t was simple to hook up
Only thing I didn’t use that was apart of the emission system was the cat, it made my exhaust to long to be able to have a side exit in front of the right rear wheel
joakwin is offline   Reply With Quote
