Old 17-05-2017, 01:59 PM   #16
Originally Posted by edk83 View Post
Just read this beginnings of thread and the car seems to have a lot of potential, hats off to you sir.
Looking forward to your turbo build, hows about a supercharger as well ?
I want this to be reliable with over 200bhp. It will happily cruise on motorway journeys due to the big wheels. Gonna be an awesome track car. Not focusing on massive power. There is always someone quicker or prepared to spend more.
Old 19-05-2017, 11:27 AM   #17
Cliff Pountney
Andrew,
Stripping the unused circuits out of the MGF loom may seem like a ball ache but it's worth it. This is a picture of what I removed, saving 3.5kg.
Cliff
Cliff Pountney is offline   Reply With Quote
Old 19-05-2017, 01:43 PM   #18
Originally Posted by Cliff Pountney View Post
Andrew,
Cliff
Yes I did same when I did Phoenix. It did take a while. The car has central locking already. Looking into doing electric windows too...
Not sure but stuff like the ABS, air con etc will want removing. The current loom is just the original all tucked away under the dash.
EDIT. Electric window winders purchased...
Old 19-05-2017, 03:15 PM   #19
CooperWorks
Thumbs up
Electric windows? You is well posh.
Old 21-05-2017, 03:51 PM   #20
Electric window winders.
Looked at the suspension setup. It is actually built on Hi Lo's. They look like they are wound up to their limit. May have to shorten the unit it get it lower. Could be interesting as also look like not been moved for years....
Old 21-05-2017, 05:36 PM   #21
If you want this to be more track focused, would you not be better off going with coilovers?
Old 25-05-2017, 03:08 PM   #22
Seen too many people ruin good cars by fitting coilovers so not going down that route. The suspension does work ok. Just needs adjusting to my my liking.
MG TF Trophy wheels and tyres collected. As expected the tyres make them look massive! I'll give these a trial over the weekend...
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
