Old 27-05-2014, 07:52 AM   #46
dad has slowed on engine progress at the moment , guess he does have other things to do
anyway , allowed me and my daughter to push on with the ecu , (well jimstim first )
this is her helping in 2009 building a jimstim for my 8v turbo ! lol ..
3 hours later , a completed and working jimstim .
Main ECU next, and then modify loom , and located coil pack/leads
Old 27-05-2014, 11:57 AM   #47
Your kids get new clothes, I'm doing something wrong,
Old 27-05-2014, 11:58 AM   #48
dry deck ,
do you need to block both block and head ?
could we just do block and leave head allone ? or is that just stupid ?
Matt
Old 27-05-2014, 04:35 PM   #49
Brumski
ECU: Mini Tec uprated Honda
If I remember correctly - do both.
Then there are no water throughput issues whatsoever...
Old 05-06-2014, 08:46 AM   #50
topfuel
love it i'm doing the same but with a 8 valve head (cheaper than a 16v) love the work are you just leaving the (timing) cam and crank seal as is or are you gonna make a plate to seal them off..
terry
topfuel is offline   Reply With Quote
Old 05-06-2014, 08:48 AM   #51
leaving as is , got the upper plate that will have the two upper seals mounted into it ,
two lower (cam and crank) seal bolt directly to block
Old 05-06-2014, 08:49 AM   #52
dad machined centre cap
and modified cam adjuster a little to give a little more clearance
Old 05-06-2014, 08:55 AM   #53
topfuel
damn your father is too clever..
terry
Old 05-06-2014, 09:14 AM   #54
wish i was half as clever ,...
hes just keeping everything simple, its easy for him to machine up round ali seal holders ..
not got tools to do laser cutting / big stuff
Old 05-06-2014, 10:55 AM   #55
topfuel
Does he want to machine more seals up ????
Old 05-06-2014, 10:59 AM   #56
i can ask .. if not i could get him to draw them up at least ...
Old 05-06-2014, 03:15 PM   #57
topfuel
that would be great.. i've got a small lathe so if you could i can knock them up myself
cheers terry
Old 09-06-2014, 12:18 PM   #58
Scrivs_89
Scrivs_89's Avatar
CC: 1380
Wow! He's really powering through this build! Wish I had the skills and tools; I've had to go the expensive option using the Force Racing conversion kit (nice piece of engineering!) and got a machine shop doing the work on mine (doing a top job of it though!). Look forward to seeing yours finished!
Scrivs_89 is offline   Reply With Quote
Old 29-09-2014, 12:19 PM   #59
sorry about lack of pictures , my google account is disabled , and i cant get it re opened at the moment , grrr
anyway
ok been awhile, sorry about dead images , my google account got disabled so have moved images.
ordered dad a 32mm cutter of fleabay , this was to big to actually fit in is mill , so he modified it ,
Then he cut a big peice of would at the correct angle for the piston to be mounted to ( to reflect valve angle , yes we think both inlet and exhaust are a little different on angle but not enough to worry)
also we are doing one size cutter for inlet and exhuast valves.
Test cutting went well , valve centres where marked by sending tool down through valve guides on head and marking piston.
now tested on old piston , block and crank need machining now , so new +20 pistons can be fitted ,marked and machined.
Old 29-09-2014, 01:04 PM   #60
Scrivs_89
Scrivs_89's Avatar
CC: 1380
Do you know what the plan is to fuel it yet? I'm not sure I can afford to go injection but not really found anyone who has used carbs instead.
