Old 07-11-2017, 10:32 PM   #1
Hoody99
Default Z12/14xep conversion issue
Hi folks I will probably get slated for this but I don't care. I am planning on a z12/14xep conversion into a mini. Why? Many reasons main one being it's what I want to do lol. I have covered all aspects of how it will be done as I am planning on using everything from the donner as the car may be coming for free. My only issue is if I am using the standered ecu and bcm and clocks etc etc from the donner, the only problem I have came across is how do deliver the signal to the speedo. The pick up for this is taken of the front wheels abs ring on the CV but like most conversions I am using mini outer cvs and there is no room for an abs ring on there and fab up a mount for the sensor unfortunately. There is a port in the gearbox for a mechanical to electric pick up but how I install that is beyond me. Any one have any ideas on how this can be done as it's the only issue holding me back
Hoody99 is offline   Reply With Quote
Old 09-11-2017, 09:00 PM   #2
wee man
wee man's Avatar
why not have inner cv machines and fit the abs ring to the that.
12.71@108.44
Old 10-11-2017, 05:58 PM   #3
Hoody99
Could be a shout but don't know if there is enough meat on them for it or space between the hub and where the CV boot attaches
Old 10-11-2017, 06:30 PM   #4
wee man
wee man's Avatar
inner cv joint there is plenty
12.71@108.44
Old 11-11-2017, 06:38 PM   #5
Hoody99
Plenty what?? The absolute rings inner diameter is smaller that the inner CV outer diameter so not possible
Old 11-11-2017, 06:54 PM   #6
wee man
wee man's Avatar
it was an idea for you to have the inner cv joint machined down if possible then have the abs ring sweated on. should this not be possible you could always strip the gearbox down have the diff machines and try and mount the pick up where the original vauxhall Speedo sensor went.
these are purely ideas that I'm throwing to try to help you. as if it was me I would just buy an dta ecu or such like and do it properly. all I was doin was tryin to offer ideas.
12.71@108.44
