Closed Thread
Old 14-06-2007, 09:58 PM   #1
BassAddict
CC: 1798
Default Parts Info - c16se
Thought I'd start listing costs of engine parts so people know what they're getting into with a new (and perhaps unfamiliar) engine!
If anyone else has bought any parts for their c16se, let me know as many of the following as poss:
Part number
Description
Cost
Where it was bought from
rough date
Here's a start - no doubt most of the stuff I bought could've been found cheaper else where !!
Engine (Gaskets and seals)
90571863, Inlet Manifold to head gasket, 6.00+vat from Evans Halshaw Oct '06
90571863, Inlet Manifold to head gasket, 7.30+vat from Evans Halshaw July '08
90409642, Exhaust Manifold gasket, 6.70+vat from Evans Halshaw July '08
90509714, Cylinder Head gasket, 23.70+vat from Evans Halshaw July '08
90411524, Throttle body to Inlet Manifold gasket, 0.54+vat from Evans Halshaw July '08
Sump Gasket, 99p off eBay, Seller williamc9836, Sept '06 (9.65+vat from Vauxhall)
90501719, Crankshaft oil seal (crank pulley end), 9.75+vat from Evans Halshaw July '08
90352112, Crankshaft oil seal (flywheel end), 17.80+vat from Evans Halshaw July '08
Engine (nuts n bolts)
90295195, Flywheel bolts (each), 1.23+vat from Evans Halshaw July '08
90469101, Cylinder Head bolts (each), 1.26+vat from Evans Halshaw July '08
Engine (Sensors):
Idle Control Valve, 29.50 off eBay, Seller VauxhallPartsWarehouse, Aug '06
Lambda Sensor, 23.50 off eBay, Seller VauxhallPartsWarehouse, Aug '06
90510183, Coolant Temp Sensor, 9.50+vat from Evans Halshaw, May '07
Engine (Ancilliaries)
Water Pump, 23.00 off eBay, Seller VauxhallPartsWarehouse, Aug '06
Engine (Plastics)
90412043, Timing Belt front cover, 7.20+vat from Evans Halshaw Sept '06
90411829, Timing Belt front cover, 7.20+vat from Evans Halshaw Sept '06
90466320, Timing Belt rear cover, 16.30+vat from Evans Halshaw March '08
Transmission:
90482454,Reverse Switch for F13,10.45+vat from Evans Halshaw June '07
AP Clutch Kit, Bargain at 4.99 brand new off eBay - seller CTP398, Aug '06
BassAddict is offline
Closed Thread
