Go Back   16v Mini Club Forums > General Public Area > Other Hybrid Chat
Old 19-06-2019, 01:01 PM   #1
adcyork
Default IACV - MG Rover 5 wire valve in MM housing?
First post for a while on here I think so hello!
I am trying to run a mini MPi IACV in a magnetti marreli housing as shown below because I already have the plenum designed and built to suit the MM IACV. However the Emerald K3 ECU I am running can not operate the four wire MM valve.
Mini Mpi IACV part number is MDQ100040 and is confirmed OK with the Emerald K3
I think the tip geometry is similar enough between the two that it will seal in the housing but have very little knowledge of how the valve finds the end stop position.
Can anyone provide any insight?
adcyork is offline   Reply With Quote
