Old 06-07-2014, 07:17 AM   #166
joakwin
CC: 1.6
ECU: Bone stock
i pulled the Honda engine harness out of the car, the engine side and the dash side
I started to pin everything out from the ecu to engine connectors
so far I have A and B done
and the only thing I found was on A22, the wire to the icm was missing, but I had a wire in A21
im gonna pin that in and see what happens
I guess is ready for the coil on plug set up, aka the icm wire for that goes to A22
and finish up D ecu connector as well
im using a P28 ecu with a edm spec dash harness, and it had a few missing wires to start out with, and i only got the engine side of the harness when i got this engine
so I think that has something to do with it
the dash harness was a later obd1 edm harness, i think out of a 96 civic or something like that
Old 06-07-2014, 10:03 AM   #167
k20/k24 allmotor
k20/k24 allmotor's Avatar
CC: 1998.2
ECU: honda stock
I know that the best thing to do. Recheck the part of the harness u made. And yes icm needs to be pined to both a22 and a21 .. But a21 is the main one. When I had it the inside harness was d15z3 and it didn't have a22 pined nether.
Old 07-07-2014, 10:13 AM   #168
joakwin
CC: 1.6
ECU: Bone stock
i wired A21 to A22
and D2 didn't have any pin in that spot
that's the battery power brake switch thingy
so im wiring that in
and the engine side of the harness didn't have a vtec pressure switch wire, but that switch is turned off in the tune, so it should be good
im up to d11 testing right now, had to get my morning coffee
i should be installing the harness again this afternoon and making everyone around my house mad with the exhaust
im known around here as the guy with the loud a$$ mini
Old 09-07-2014, 07:17 PM   #169
joakwin
CC: 1.6
ECU: Bone stock
I just ordered a budget rywire harness and chassis adapter harness
They had it in stock, I'll probably have it in my hands in about a week or so
Old 20-07-2014, 08:05 PM   #170
joakwin
CC: 1.6
ECU: Bone stock
changing out the huge yellow top battery for this powervamp 30 battery
the old mount for the mini battery box fits this battery just right,
I just have to weld on some tabs to the side for the threaded rod
I ordered up a junction block for the power side right off the bat
its going to have the starter wire, alt wire, and cab power wire connecting to it
going to mount that right behind the battery
Old 20-07-2014, 08:09 PM   #171
joakwin
CC: 1.6
ECU: Bone stock
painted the valve cover as well
the rywire harness left Chicago on the 18th of july at 10:40 pm
probably have the harness in my hands like Tuesday or Wednesday
Old 23-07-2014, 03:42 PM   #172
joakwin
CC: 1.6
ECU: Bone stock
new engine/chassis harness, the alt wiring was ext 24inches
Old 23-07-2014, 05:43 PM   #173
k20/k24 allmotor
CC: 1998.2
ECU: honda stock
That going to look so much better..
Old 25-07-2014, 07:03 PM   #174
joakwin
CC: 1.6
ECU: Bone stock
had a wiring issues but the engine started up 1st time even with it, just wouldn't turn off by the key switch
I made a mistake with the wiring, I hooked up constant battery power to the wire that needed switch ign power
swapped that wire over to switch ign that has power in crank and run
and the engine turned over 1st time again
engine seems to be running a lot better now as well
tomorrow im going to the junkyard to get a pig tail off of a stock 02 sensor
I need to wire in my wideband
only need one wire to connect to the stock 02 sensor plug
Old 25-07-2014, 07:24 PM   #175
k20/k24 allmotor
CC: 1998.2
ECU: honda stock
I'm happy that it all working out. I'm even thinking about getting one of them harness for the rwd one.
Old 26-07-2014, 07:38 AM   #176
joakwin
CC: 1.6
ECU: Bone stock
I got the budget harness for the engine, and I really like it
the mil spec chassis adapter harness is nice as well
they hooked the starter relay up for ground trigger, but I ended up just grounding it and cutting one wire to make it be able to trigger off of the mini key switch
but overall, it was a super simple harness to install
I took my time, but I could have probably installed it in less then 2-3hrs
Old 30-07-2014, 05:27 PM   #177
joakwin
CC: 1.6
ECU: Bone stock
making exhaust tip for my twin box set up now
Old 30-07-2014, 09:04 PM   #178
joakwin
CC: 1.6
ECU: Bone stock
test fit before welding
junkyard del slow d16z6 dizzy clean up
Old 30-07-2014, 09:07 PM   #179
joakwin
CC: 1.6
ECU: Bone stock
went to the junkyard today and pulled some parts from a del slow d16z6
a dizzy, map sensor, tps sensor
I tried to get the iat, but my screw driver was to long and I wasn't about to pull the intake to get at that sensor
I tried to get a d17 valve cover, but the yard wouldn't sell it to me because then that engine could get water in it, oh well i'll find another one some other time
Old 30-07-2014, 09:19 PM   #180
joakwin
CC: 1.6
ECU: Bone stock
I still have the hot stalling problem,
so that's why I got the other dizzy from the del slow, im going to install it tomorrow
and ones the exhaust is mounted back up to the car, I should be able to run it up to see if im good or not
im running out of sensors to replace
