Old 26-07-2014, 05:23 AM   #181
NIce
Old 26-07-2014, 03:38 PM   #182
richie08
richie08's Avatar
CC: 1396
ECU: Rover mems
Mot passed on the second attempt today. So that's it taxed, insured and motd.
Bloody scary to drive, I'm paranoid about every wee noise and the slight drip of transmission fluid from the diff output seal produces an obscene amount of smoke, but I'll do some refinements before the massive drive
Old 26-07-2014, 04:58 PM   #183
apbellamy
apbellamy's Avatar
ECU: SC Typhoon
Good skills. What did they pull it on?
Old 26-07-2014, 06:35 PM   #184
richie08
richie08's Avatar
CC: 1396
ECU: Rover mems
Insufficient rear braking, adjusted the shoes till they were dragging and trebled the brakes. then tightened handbrake cable and it's sorted
Old 26-07-2014, 07:40 PM   #185
apbellamy
apbellamy's Avatar
ECU: SC Typhoon
Nice easy fix then. I had to do a drive test with the tester in my car as the LSD would have broken their rollers
Old 26-07-2014, 10:51 PM   #186
richie08
richie08's Avatar
CC: 1396
ECU: Rover mems
So, I rocked up for my mot at 9am. Had an advisory for slight play on the nsf front wheel bearing, and a fail for the rear brakes not recording much effort.
So, I got about 0.5 mile from the mot station and lost all drive. Thankfully, someone stopped and towed me home. I realised that the drive shaft had popped out of the diff slightly.
Basically, vibrations from nsf hub nut being loose.
I tightened it all up and reinserted the shaft,and all good.
Back brakes just needed some adjustment.
Retest also passed this morning
Old 27-07-2014, 01:55 PM   #187
richie08
richie08's Avatar
CC: 1396
ECU: Rover mems
Thanks guys, tracking sorted today and that's changed it from being bloody scary, into bring a very nice drive
Unfortunately I'm still having issues with the driveshafts popping out of the diff, and I'm losing all the gearbox oil in the process. I don't have time to look at it, so going to take it into a trusted local motor engineers and get them to take the shafts out and see what's up with it
Old 27-07-2014, 02:04 PM   #188
There's a little circlip type clip at the end of the driveshaft that keeps it in place, is that there/in good order?
Also could be worn diff bearings.
Old 27-07-2014, 02:19 PM   #189
richie08
richie08's Avatar
CC: 1396
ECU: Rover mems
Thanks for that. I guess that I'll need to see what happens tomorrow then
Old 27-07-2014, 04:07 PM   #190
getthewheelsinline
getthewheelsinline's Avatar
Send a message via MSN to getthewheelsinline
Where did you get the tracking down in the end?
I had the same problem with my Allspeed billet shafts into the inner cv's. As they had laid about a while the shaft had attached itself to the inner cv so it restricted the shaft movement on the cv splines. Took a good run to free everything up. As above ensure the circlips are present on the CV stub and also on the shafts themselves to limit full travel in the cv.
www.minis4monkeys.co.uk
getthewheelsinline is offline   Reply With Quote
Old 27-07-2014, 05:54 PM   #191
richie08
richie08's Avatar
CC: 1396
ECU: Rover mems
Thanks Callum, had the tracking done at Craighill tyres, next to Sainsburys in Irvine.
The shafts have been lying a long time, stood upright in my garage so there's a very strong chance the inner CVs are stuck together.
Don't fancy a wee job rebuilding my Driveshafts for me, do you?
Old 27-07-2014, 08:18 PM   #192
getthewheelsinline
Ok - I'll keep that place in mind!
Sadly swamped at work just now mate - therefore no time even for the stuff I want to do - ha!! Sounds like everything just needs freeing up so you mechanic should manage that easy enough. I eventually stripped everything down, cleaned out the joints with diesel, re-packed with cv grease, and then banded the boot with the metal banding tool I bought. Done mine in a could of hours - so should be a doodle for your man!!
Old 27-07-2014, 09:48 PM   #193
richie08
richie08's Avatar
CC: 1396
ECU: Rover mems
I hope so! I haven't even spoken to them yet, I'm just dropping it off at 6am and posting keys through their door, and will phone at 9am when they open lol
Old 06-08-2014, 11:22 AM   #194
Richie , how was the show, i hope your home safe and not stuck in england.
Old 06-08-2014, 11:44 AM   #195
richie08
richie08's Avatar
CC: 1396
ECU: Rover mems
Show was brilliant, and it was one he'll of a shakedown for the car. It did help me identify a few problems:
1. N/s cv boot leaking,
2. Broke a weld on my gear linkage (big thanks to Tomm for repairing for me so I could drive it home)
3. Intermittent fuel starvation issue, which was due to a piece of hose collapsing,
4. Fuel sender doesn't work
So it's all straightforward stuff to sort.
