Old 21-12-2017, 08:29 PM   #1
Default Cam belt tension?
I have fitted new cam belts and a water pump at the weekend and used the (Weak) spring to set the tension of the belt, but to me the belt is slack! as in I can get about half a twist in the belt on the long side. I was always told and shown to set the tension so you could get about 1/4 twist in the belt and that would be the right tension and with a little bit of force I can get the tension pulley to go to it's max adjustment which I know not to be right? What am I doing wrong? or do I use the spring to tension the belt even though to me it's a bit loose.
Gadget
Old 22-12-2017, 08:37 AM   #2
Auto tensioner or manual? With the manual (vvc and mems 1.9) I set it so you can get between 1/4 and half turn on the long side so it doesn't sound too far off. You don't want to overtighten it on the vvc engine as that can damage the bearings in the vvc mechanism.
Old 22-12-2017, 09:38 AM   #3
This is the kit I bought it comes with the little spring for auto tensioning when you fit the new belt then remove it when it's all fitted. http://www.ebay.co.uk/itm/FOR-MG-MG-...72.m2749.l2649
Forgot to say mine mems3.
Old 22-12-2017, 11:19 AM   #4
That's actually a manual tensioner - all vvc engines (mems2 & mems3) are manual tensioner like that, it's just the Non-vvc mems 3 engines that use auto tensioner. The spring that comes with it is just supposed to help you set tension but it should still be set manually, personally I never use the spring as I find them to be inconsistant. I just set it manually so I get between 1/4 and 1/2 a turn (twist) on the longest straight bit then turn the engine over by hand a few times and re-check (I normally do this 3 or 4 times to be sure). If the belt is too tight it will whine when you start it up and will damage the vvc mechs.
Old 22-12-2017, 12:51 PM   #5
Ah right I see what your saying now.
