Old 16-10-2017, 06:19 PM   #16
http://www.megamanual.com/ms2/V3assemble.htm
Old 17-10-2017, 12:20 PM   #17
webster444
ECU: Soon to be megasquirt
Ah right that is a different manual to the one I used, i used the msextra manual. I will need to keep an eye on the crank sensor when I come to trying it out and see if I need to replace that capacitor you pointed out
webster444 is offline   Reply With Quote
Old 24-10-2017, 08:39 AM   #18
toothlogger in tunerstudio is a saver !!!
make sure you purchase tunerstudio if you have not already, well worth the $$$
Old 01-12-2017, 06:45 AM   #19
Mini Vlatko
Mini Vlatko's Avatar
I have assembled my MS1 V3.0 a few weeks ago and as Iím planing to use it with Vauxhall DIS PACK ignition unit I've also installed two
Bosch BIP373 Coil Drivers.
I have soldered them on the PCB, following the instructions on site but now I wander, do I have to remove or do something with Q16 transistor?
I have read somewhere that there is no need to remove it and just leave it in peace as an option to revert to direct coil control at some point.
Old 01-12-2017, 07:17 AM   #20
been a while , but remember about leaving something
also i never had any luck with vauxhall coil ( did not waste lots of time trying to get it to work ) i went with a Ford coil pack which is known to work out of the box ( used this on my K1100 to )
Old 04-12-2017, 05:44 PM   #21
Mini Vlatko
I ended up with removing Q16 transistor...
We'll now have to wait and see if it'll work
