Old 10-10-2018, 09:00 AM   #1
ochumi
Default about CRX electrical fuse box D16A9
hi i want to ask you, if is it possible to remove the fuse-box (pictures) and how i can do it, because there a lot of cables that im not going to use... and i want to save some space down dashboard
thanks
ochumi is offline   Reply With Quote
Old 10-10-2018, 04:01 PM   #2
Throw the top one away.
Find / make space for the bottom one
Old 11-10-2018, 12:57 PM   #3
ochumi
i want to know if i remove the dash fuse box and add new a smaller fuse box i will get an ecu errr for example for not use the unit control (alarm, lighting wiper...)
Old 11-10-2018, 04:26 PM   #4
This setup is OBD0 right ?
You can remove the dash fusebox and wire in a new one suited to your needs, without any problems.
Apologies, I thought the bottom picture was the engine bay fusebox.
From memory, if you're using the Mini ignition switch and key, there's no issue with removing the alarm complete - but someone else ought to clarify this.
Old 11-10-2018, 04:39 PM   #5
GEORDIE SP1
GEORDIE SP1's Avatar
In mine I just binned all that and put in a 6 gang fuse holder and run all my feeds from that,
Get your ECU de immobilised if it has one, not sure with obd0
Old 12-10-2018, 08:18 AM   #6
arterz
arterz's Avatar
ECU: OBD0
You also need to separate ecu plugs from entire vehicle harness, IIRC the ecu needs 5 wires to run
easy job
mitsos mini 16v
Old 25-10-2018, 11:07 AM   #7
ochumi
thanks,
yes its OBD0 im looking that from main relay gos 2 wires to the fuse box and anonther wire to a brown connector a can cut them witouth problems? what do they use for?
