Old 23-09-2018, 10:51 AM   #16
hebby
ok i shall go google and ebay see what i can find. cheers monkey
hebby is offline   Reply With Quote
Old 23-09-2018, 10:58 AM   #17
hebby
Old 23-09-2018, 11:00 AM   #18
hebby
well if im right 0.625 should be 15.875mm so im sure there similar from a girling to a ap racing one.
Old 23-09-2018, 11:41 AM   #19
hebby
ok so im going to buy this, and use the honda slave thats on the gearbox if this is the right slave of corse
Old 23-09-2018, 11:43 AM   #20
monkey
monkey's Avatar
ECU: A box of chips
I'd try and buy something thats a known brand like Wilwood or Girling itself. I'm not sure how durable the cheaper versions would be to be honest!
This should work well with the Honda slave, uncommon to actually change the slave on the gearbox itself, usually people change the master cylinder itself.
Old 23-09-2018, 11:47 AM   #21
hebby
Ok I shall keep looking about until I find a better manufacturer, I might buy a new slave as it looks a bit rough so I can get another Honda one, then at least I shouldnít have any issues with old parts, thanks everyone
Old 23-09-2018, 02:51 PM   #22
Sorry Monkey, you're right. Girling it is.
Old 24-09-2018, 09:23 AM   #23
monkey
monkey's Avatar
ECU: A box of chips
No worries at all buddy, we're all learning and helping each other out here
Old 25-09-2018, 03:08 AM   #24
Harley
Were there different master cylinders available from Honda?
I keep seeing post after post here about people wanting a better clutch pedal because it feels too heavy or on/off - is everyone going soft or something? :P
I'm running a honda master cylinder and honda slave and have no issues with the setup (both standard CRX parts). Feels like a modern car (with a slightly heavier setup) or even my standard SPI mini doesnt seem that much different. I even drive the vtec mini car without shoes on and I'm only a 50kg person - it's not like I have a lot of weight to fight it with!
Old 25-09-2018, 07:58 AM   #25
hebby
Ummm Iím guessing there must be different on the crx ? Iíve never driven a 16v mini anyway so Iím not sure as Iíve nothing to compare it with, my spi mini just felt like any other mini if I could get something like that I would be happy
Old 25-09-2018, 06:34 PM   #26
No, mine's from a CRX and it no way feels like a modern clutch. Don't know the answer really, but guess the .625 Girling might be it
Old 25-09-2018, 06:43 PM   #27
hebby
there cheap enough on flebay and a few
hours work one weekend. worth a try
Old 26-09-2018, 01:55 PM   #28
monkey
monkey's Avatar
ECU: A box of chips
From memory, using the Girling master wasn't terrible it felt like a mini clutch to me. It certainly wasn't a super light modern car clutch though, if thats what you're looking for.
Old 26-09-2018, 04:13 PM   #29
hebby
I quite like the slightly heavier clutch, the modern euro boxes are two light, no feel to them, so the mini will feel like a mini too with the clutch peddle having some feel to it, cheers
Old 28-10-2018, 11:45 PM   #30
Mark D
Mark D's Avatar
CC: lots
I used the original master cyl on mine and not only was it very heavy but it also over threw the release bearing, pushing the friction plate back onto the flywheel. I fitted a girling cyl but I’m sure it was a .5, not a .625
