Old 21-09-2018, 12:47 PM   #1
pompeyal
pompeyal's Avatar
Default Loads of different clutch stories
Hi guys, been sifting through the search on B16 hydrualic clutch slave along with standard mini master and I think I will be there an age to find exactly what I need to know, as I have been building this car for a looooong time now I need to get things done sooner than later, if you know what I mean, what problems will I encounter and best remidies as I will be starting on that soon, cheers....
Old 21-09-2018, 01:57 PM   #2
Dopeshow
Hi,
Not at that stage yet but from my research, if you use a mini master it does not work very well, heavy pedal and more of an on/off rahter than a nice feel. Most cost effective option is to make a spacer and use the honda master which are around £65 other option if to buy a AP racing 14mm master and mod the arm to suit. roughly £175 <http://www.apracing.com/car/cylinder/cp2623_1cd_iss16.pdf>
There are other more eloborate (expensive) options such as going for a hydraulic release bearing which are around £290, not sure what master you will have to use though. My friend has one of these in his 550bhp Evo and it works great.
https://h-tune.co.uk/clutch-masters-...onda-b-series/
Old 21-09-2018, 02:06 PM   #3
I've just bought one of these for my build as I need the space in front of the box where the slave sits for my rad.
There is one build on here which one was used. IIRC he ended up using the standard Mini one with it. I'll have a look and try and post a link
Old 21-09-2018, 02:10 PM   #4
http://www.16vminiclub.com/showthread.php?t=37255
From the bottom of page 1 onwards
Old 21-09-2018, 02:38 PM   #5
pompeyal
pompeyal's Avatar
Thanks guys, looks like I need some cash....lol
Old 21-09-2018, 02:55 PM   #6
Honda slave / Honda master / Mini pedal is still a bit on-off.
Watson's do a master cylinder kit, all ready to bolt straight in (think it's 5/8"), which is said to give the best pedal feel.
Old 21-09-2018, 06:05 PM   #7
hebby
is it not possable to just change the slave cylinder ? im running a mini servo and mini master was hoping to just change the slave to compansate
hebby is offline   Reply With Quote
Old 21-09-2018, 10:20 PM   #8
I don't rate the mini clutch slave cylinder !! And Shure there's better out there, only good thing I can say is that it was easy to change on a mini before verto type, just as well for the amount of times they let me down , problem if it's hard to get at with honda location ,
Old 22-09-2018, 02:35 PM   #9
monkey
monkey's Avatar
ECU: A box of chips
I've used the Watsons kit before which worked very well for me. Quite smooth from what I can remember, a bit like a orange plate clutch on an a series. The AP 14mm is supposed to be light and easy but I've gone for the Watsons kit again this time round.
Old 22-09-2018, 03:19 PM   #10
hebby
Well what exactly is the watsons kit ? I canít see Geoff manufacturing his own, it will be something from another car, any photos of the ď kit ď Iím sure a bit of research would one up with the correct parts from other cars.
Old 22-09-2018, 05:21 PM   #11
Yeah, it's an AP part I think, with modified operating arm to fit straight into a Mini
Old 22-09-2018, 05:56 PM   #12
hebby
well ap make loads of parts for cars, it wouldnt be to difficult to find out where it comes from with some photos...would anyone like to post some up please then we can all have a nice clutch
Old 22-09-2018, 11:29 PM   #13
Sleepy Stu
Sleepy Stu's Avatar
ECU: Hondata S300v3
I have the AP 14mm but I have not got the mini on the road yet so cant tell you how it feels?
Build Diary
Sleepy Stu is offline   Reply With Quote
Old 23-09-2018, 10:40 AM   #14
monkey
monkey's Avatar
ECU: A box of chips
The Watsons kit doesn't come with an AP master cylinder (which I thought it did). I can't quite remember the bore size of the cylinder either as its all packed away somewhere but it comes with the arm/rod modified to suit a mini. The kit is the master cylinder, a braided line straight to the slave and a reservoir pot for the fluid with all the fittings. So you pretty much have everything to have a working clutch providing you have Honda slave already.
Old 23-09-2018, 10:49 AM   #15
monkey
monkey's Avatar
ECU: A box of chips
Digging through my old photobucket account the Watsons one is supplied with a Girling .625" master.
