Old 03-03-2018, 08:54 AM   #181
I quite liked the idea of colour coded hoses
Old 06-03-2018, 05:35 PM   #182
geachy87
geachy87's Avatar
CC: 1.8t
ECU: Kmaps
Got the gearbox mount hole drilled and bolted up, just waiting on some 1 piece mpi bushes coming so I can finish making the brackets for the engine steady and get them welded on.
This is the side that will be welded onto the front bar of the subframe and Iíve started making one up that bolts onto the bellhousing but didnít get a photo of that
Old 08-03-2018, 02:38 PM   #183
geachy87
geachy87's Avatar
CC: 1.8t
ECU: Kmaps
Bushes finally arrived today so I fitted them to the engine steady
Then welded the bracket onto the subframe and finished making up the one for the gearbox, the gearbox one is boxed in on the bottom and the rear, hard to see in the photo but itís plenty strong enough
Iíll tidy up the welds at the front when Iíve got some more free time
Old 08-03-2018, 03:33 PM   #184
My thoughts are:-
1) The bracket on to the gearbox looks like it would fracture with the lateral force on it. I think most of us have seen the rear engine steady bracket on an A-series (behind diff) fracture and its a lot thicker than your bracket. Could you attach the steady direct to the gearbox where the lower bracket bolt is ?; and
2) The force on the subframe bracket will be pushing against the weld on the front of the subframe. I reckon that will fracture too over time. Could you reverse the bracket and tweak it so it sits against the back of the front bar so you'd be pushing in to the bar rather than against the weld ? It'd be much stronger that way.
Old 08-03-2018, 03:58 PM   #185
geachy87
geachy87's Avatar
CC: 1.8t
ECU: Kmaps
My thoughts are:-
Completely agree about the bracket on the gearbox, just couldnít think on a better way to do it, Iíll have a rethink and come up with something better..
Iíll wait and see if the one on the subframe proves me wrong but I think itíll be fine
Old 09-03-2018, 10:56 AM   #186
Has the front bracket been welded to the underneath of the front bar as well ? The pic is a bit dark to tell. If not then adding weld there will increase the strength of the bracket in resisting the force of the engine moving.
Old 09-03-2018, 11:10 AM   #187
geachy87
geachy87's Avatar
CC: 1.8t
ECU: Kmaps
Yes, both L shaped parts have been welded on the front and bottom on both sides of each part, so should be plenty strong.
Been looking at it though and there is only one hole on the bellhousing that suits the size of bolt for the engine steady, the rest are obviously far too big, but to use that one Iíll need to weld brackets for the steady onto the top of the subframe bar, so Iíll be doing away with the one thatís already there
Old 09-03-2018, 08:32 PM   #188
geachy87
geachy87's Avatar
CC: 1.8t
ECU: Kmaps
Had to do a bit of surgery on my passengers seat today, the outside of the head support and the rollcage wanted to occupy the same space, took the cover off and cut some of the return lip off, still left some for strength. With the cover on you canít tell and it fits in nicely now
If anyone is thinking on getting these seats, they would go in perfectly if you donít have a rollcage
Old 17-03-2018, 12:23 PM   #189
andy86
how do you find the mirco seats other than the hassle to fit. I've been looking at the its without the head restraint wings. they're a lot cheaper than the suzukas I was going to go for.
andy86 is offline   Reply With Quote
Old 18-03-2018, 12:23 AM   #190
geachy87
geachy87's Avatar
CC: 1.8t
ECU: Kmaps
Canít fault the quality for the price, seem really well made and these ones are really comfy for buckets. All Iíll say is check the shoulder width, when I looked these were the only ones in the range that looked like they would fit, theyíre 570 width at the shoulders as far as I can remember, think the rest were around 590 or there abouts. Really happy with them though
Old 20-03-2018, 11:39 AM   #191
geachy87
geachy87's Avatar
CC: 1.8t
ECU: Kmaps
Started plumbing in the intercooler, just need to finish the other side then itís onto the oil and water lines for the turbo
Old 27-03-2018, 11:33 AM   #192
geachy87
geachy87's Avatar
CC: 1.8t
ECU: Kmaps
Still need to finish it but this should be more suitable than the last attempt..
Old 12-06-2018, 01:14 PM   #193
geachy87
geachy87's Avatar
CC: 1.8t
ECU: Kmaps
Kinda lost motivation on this so currently sorting the wiring to get it running and hopefully get the motivation back to finish it
Old 19-06-2018, 03:33 PM   #194
geachy87
geachy87's Avatar
CC: 1.8t
ECU: Kmaps
First start
https://flic.kr/p/28n1sc4
Old 20-06-2018, 08:23 AM   #195
Geehawk
Geehawk's Avatar
Mini T-Shirts
TheClubman.co.uk
