Go Back   16v Mini Club Forums > General Public Area > Links
Old 22-12-2011, 08:12 PM   #1
Body Stylist
Body Stylist's Avatar
Default Full Carbon Fibre Sprint
This, at the moment is a total one off, but if i where to start supplying them, what would people be preparred to pay?
https://www.facebook.com/absmotorspo...type=2&theater
For the best range, the best prices, the fastest delivery and even forum discounts...
can only be www.absmotorsport.net
Body Stylist is offline   Reply With Quote
Old 22-12-2011, 08:48 PM   #2
JoBu
JoBu's Avatar
How much could you supply them for? What is the materials and labour cost to you? Let alone your mark up then VAT on top of that....
JoBu is offline   Reply With Quote
Old 22-12-2011, 08:52 PM   #3
Body Stylist
well obvouisly i know what that one has cost to manufacture, but it may or may not surprise people, im mainly fishing for peoples views of what they would expect / would be happy for the price to be...
Old 22-12-2011, 08:53 PM   #4
Body Stylist
http://www.absmotorsport.net/mini/bo...bodyshell.html
Old 22-12-2011, 09:02 PM   #5
JoBu
JoBu's Avatar
I would have thought its got to be 5-6K plus VAT?
Old 23-12-2011, 09:06 AM   #6
apbellamy
apbellamy's Avatar
ECU: SC Typhoon
Nice
Old 23-12-2011, 05:09 PM   #7
Basil
CC: 1598
How heavy is it?
Old 05-01-2012, 09:48 AM   #8
Body Stylist
prices now up
Old 05-01-2012, 10:33 AM   #9
Kaison
Kaison's Avatar
I'd love to see the car completely built to show off how well it all fits together.
Would it be bonded together or fastened/bolted?
I only bow under braking.
Old 05-01-2012, 12:04 PM   #10
Body Stylist
the internal sections bond in place, the front end can be bonded or made removable, the doors and boot use original hinges
Old 05-01-2012, 12:05 PM   #11
Body Stylist
the black one was a development shell, and will be built by the company who contracted us this year.
Old 06-01-2012, 02:13 PM   #12
bousfield19
Send a message via MSN to bousfield19
would love to see one made showing weave would look amazing cant afford one though unfortunately lol
bousfield19 is offline   Reply With Quote
Old 06-01-2012, 04:42 PM   #13
isjakar
This looks great, very interesting. The price seems well within reason, for a "complete" new GRP Mini with a carbon layer. But weight is critical. How much does the set weigh, and how much weight is saved compared to a steel equivalent?
isjakar is offline   Reply With Quote
Old 03-02-2012, 07:15 AM   #14
VT-Doo
VT-Doo's Avatar
CC: 1797
ECU: Hondata S300
As mentioned, it's comes down to weight and strength over the original shell.
Ian
VT-Doo is offline   Reply With Quote
Old 07-02-2012, 09:50 AM   #15
Body Stylist
The Shell shown in the images has been built to a customer specification that is above what we would recomend, but is Very Strong.
that shell had the following construction -
Black gel coat, 2 layers, 3 around seam lines.
1 layer 450 CSM
1 layer 2x2 Carbon Fibre 300gm
2 layer quadaxel at 90 degree rotation
at suspension and subframe mounting areas and additional layer of quadaxel and carbon where added.
at the join from upper to lower shell and bulkhead, the components where bonded, the stitched with another layer of quadaxel and a layer of carbon fibre.
that shell and all components have been weighed (including packaging - well wrapped, but not worth unwrapping until the parts are required) at 115 kilo
our standard layup will take another 20 - 30 kilo off that and is suitable for road use.
we could make it lighter still but would advise a full rollcage with subframe pickup points
