Old 02-03-2017, 06:17 PM   #16
joltfreak
joltfreak's Avatar
ECU: Standard-ish
I need to trim the front arches to clear the 13 inch wheels:
Here is what it looks after the trimming. I left a little metal there to allow me to put a lip back on the fender to keep some strength in the fender.
Old 27-03-2017, 01:20 AM   #17
joltfreak
joltfreak's Avatar
ECU: Standard-ish
I have picked up my wheel flares and have fit them to the van.
Old 27-03-2017, 01:29 AM   #18
joltfreak
joltfreak's Avatar
ECU: Standard-ish
They have turned out pretty good!
Also decided to use the inno chrome instead of the MK1 one. Liking it!
Old 14-05-2017, 08:33 PM   #19
joltfreak
joltfreak's Avatar
ECU: Standard-ish
Been a while since i have updated:
My gauges came in from Speedhut and I decided to keep the centre binnacle instead of a full dash to try to keep it looking "kind of" period
I also picked up a new binnacle from ABS and I'm happy with the result.
Old 14-05-2017, 08:37 PM   #20
joltfreak
joltfreak's Avatar
ECU: Standard-ish
The body has been stripped back down and is currently at the paint shop:
Old 14-05-2017, 09:24 PM   #21
joltfreak
joltfreak's Avatar
ECU: Standard-ish
I've picked up my intake after i had it modded:
It looks like the fuel rail fouls the air temp sensor. So it looks like i will need block off the current location and move it.
The last issue I had is that it looks like throttle body will foul with the fuel rail.
Old 14-05-2017, 09:30 PM   #22
joltfreak
joltfreak's Avatar
ECU: Standard-ish
So I've cut the return end off the fuel rail (on the TB side) & tapped and plugged the end off.
I have also blocked off the current location of the intake temp sensor and order a bung to relocate it.
I think with this and maybe a TB spacer i may be clear for the TB linkage once it comes in and confirm, i will order a fuel regulator with a return and i hope it will solve it all.
Old 15-05-2017, 12:18 AM   #23
joltfreak
joltfreak's Avatar
ECU: Standard-ish
While the body is at the shop and im waiting for parts to arrive, i also changed the timing belt and put a fresh clutch in.
Old 15-05-2017, 12:24 AM   #24
the mini van is so nice it makes me touch myself,,
Old 19-05-2017, 03:04 AM   #25
joltfreak
joltfreak's Avatar
ECU: Standard-ish
I cant wait until its out of the paint shop......
Old 19-05-2017, 03:15 AM   #26
joltfreak
joltfreak's Avatar
ECU: Standard-ish
The throttle body spacer came in today and it looks like it will work well:
Old 19-05-2017, 03:20 AM   #27
joltfreak
joltfreak's Avatar
ECU: Standard-ish
Next, is to weld the bung to relocate the intake temp sensor:
Old 07-08-2017, 12:49 AM   #28
joltfreak
joltfreak's Avatar
ECU: Standard-ish
Been a while since I've updated.
I messed up my hand and cut it down to the bone and also cut two tendons for my thumb in the process.
Had surgery and got it stitched up again:
I hand my hand in a cast up until last week and was not able to do too much. Starting physo this week to try to regain full movement and strength and try to avoid another surgery.
Old 07-08-2017, 12:51 AM   #29
joltfreak
joltfreak's Avatar
ECU: Standard-ish
In the meantime, i was able to finish up having the bung welded into a new location on my intake:
It should do the trick.
Old 07-08-2017, 12:55 AM   #30
joltfreak
joltfreak's Avatar
ECU: Standard-ish
My new race header came in and i was able to wrap it and mount to my motor. The motor is ready and just waiting for the body to come back from the paintshop (hopefully by next week...)
Getting a bit stir crazy now waiting........
