Old 15-11-2018, 08:45 PM   #181
Hi Jack, looks like you're getting this well set up now. I saw you wrote elsewhere about having a problem with not enough thread on the tie bar to correct the geometry. How did you get round it? And what kit did you borrow and was it easy to use?
Old 15-11-2018, 09:27 PM   #182
jackjewell93
ECU: Emerald
Just added some more threads to the tie bar, scales and turn plates I bought Iíve borrowed a sealey castor camber gauge itís fairly simple to use no issues with it
Old 16-11-2018, 05:36 PM   #183
Oh I see. I thought you'd cut them too short and run out the other way. How does the gauge fit to the wheel? I've seen them used on a brake disc with the wheel off and the weight off, but that defeats the object as the suspension isn't in the natural running position - looks like you mounted it to the wheel?
Old 16-11-2018, 05:39 PM   #184
jackjewell93
ECU: Emerald
It’s mounted to the wheel fits a weller wheel perfect will try and get a close up picture tomorrow
Old 19-11-2018, 02:20 PM   #185
Ha ha I hadn't spotted the wheel change. I was trying to work out how you'd got the magnet to stick to your alloy split rims!
Old 05-12-2018, 08:32 PM   #186
jackjewell93
ECU: Emerald
Decided to remake my dash board got a tablet to link to the emerald just need to make a holder for the tablet and the dash is finished
Old 08-12-2018, 04:29 PM   #187
jackjewell93
ECU: Emerald
Made a start on the switch panel waiting on couple bits to finish that off also bought a carbon boot lid
Old 10-12-2018, 01:41 PM   #188
Hi Jack. I'm confused..... looks like good progress but you're selling off a load of parts on Facebook - what's the plan?
Old 10-12-2018, 07:37 PM   #189
jackjewell93
ECU: Emerald
Default Aa
Got family priorities seeing what interest there is if not enough then will keep it in the garage for a while and assess the situation later next year
Old 25-01-2019, 05:52 PM   #190
jackjewell93
ECU: Emerald
Wired up the gauges, carbon boot lid fitted also tried some 13Ē wheels clearance on the rear was fine front arches it was hitting so keeping the 10s for now.
Old 23-04-2019, 09:08 PM   #191
Broomel
Sweet mini, you gonna actually use it this summer ?
Old 24-04-2019, 07:41 AM   #192
He was breaking it a month or so ago on the Facebook 16v Mini page
Old 24-04-2019, 05:14 PM   #193
jackjewell93
ECU: Emerald
Itís a special talent you have to be a bellend 99% of the time 😂😂
