Old 19-08-2014, 12:52 PM   #76
fanny .. hehe
Old 19-08-2014, 01:06 PM   #77
gimenofl
gimenofl's Avatar
CC: 1380
ECU: Typhoon Specialist Co.
So u see my car and think of tranny's..? The day I get you at the lights all you'll get to see is my rear end :-9
Old 19-08-2014, 03:59 PM   #78
jimfai
how is your dad matt?
on a serious note with this thread: cant say enough good things about how helpful all of you have been with my car, not a lot of support for these on this side of the pond. really is and has been appreciated.
and i only think fond thoughts of trannys, not negative jim
2.0L vtec, custom subby, in a non extended nose saloon. mini saloon with an MI16 PUG driveline. possible zcars saloon underway. 1960 MGA with cologne 2.8L ford conversion.
jimfai is offline   Reply With Quote
Old 19-08-2014, 05:54 PM   #79
gimenofl
gimenofl's Avatar
CC: 1380
We want pictures of that nice engine that will soon idle like silk...
Old 23-08-2014, 01:14 PM   #80
jimfai
couple questions for you guys about engine mounts: i had to burn out the rubber on my mounts and bolt them direct as solid mounts in order to get the motor to sit low enough to clear the bonnet. did you fellows do something similar? different bonnet? or find another way to mount it? i am waiting for my engine steadys to arrive but thought i would ask before i mount them. thanks, jim
Old 23-08-2014, 07:45 PM   #81
gimenofl
gimenofl's Avatar
CC: 1380
Solid mount is absurdly rigid. Despite all promises that the k head fits unders the standard bonnet I was also facing the same problem. Solved by making a bulge. You have seen I have a fibre flip front. In case you want to make things really complex but clean you can fit an auto subframe, they are wider and the engine sits lower.
Old 03-09-2014, 06:02 PM   #82
jimfai
added the two lower stabilizers that mount to the rear of the subby, along with the stock mounted one from the bulkhead to the tranny (gearbox) it seems to have taken most of the vibration out of the car, still looking at mounting another from the water pump to the bulkhead. anyone else done this?
. so tuning update. took it to my neighbor that repairs motor bikes yesterday and had the tb's balanced, make a huge difference in running and no back fire on deceleration. planning on hooking up the ecu to my laptop with the tuning guru friday and see what he thinks. getting nearer completion and liking how it runs more and more,
Old 03-09-2014, 06:06 PM   #83
gimenofl
gimenofl's Avatar
CC: 1380
Good man. Can you give us more data on how the gent balanced the TB? Thanks in advance as I am into balancing after 15000 Km or so.
Old 03-09-2014, 11:17 PM   #84
jimfai
he had a set of hanging gauges (4) with hoses on them and the hoses just slipped on the the ports on the lower edge of each tb, they have little rubber caps just pushed on, started the car and adjusted each one with a screw driver from left to right to match the one nearest the gearbox. number 2 was pretty close on mine and 3 and 4 were way off. took him all of 15 minutes, best $10 i have spent in some time. did the air /fuel same i would using a small hose and just listening.
Old 04-09-2014, 05:54 AM   #85
i made my own balancer years ago , worked perfect :
Old 04-09-2014, 08:25 AM   #86
Did you use some kind of dye, Matt? I did something similar, but discovered that if theyre REALLY out of balance then it just gets sucked into the ports
You can buy a gauge for twin carbed bikes on ebay for about £30, use this to match them in pairs and then balance the pairs together worked a treat for me, ran miles better!
Old 04-09-2014, 03:09 PM   #87
think i used motor oil , well some kind of oil
Old 04-09-2014, 04:04 PM   #88
gimenofl
gimenofl's Avatar
CC: 1380
Hi,
Nice to see the progress.
I know it's not cheap, but you will be balancing the TB once in a while, may be you want this: http://www.ebay.co.uk/itm/Morgan-Car...item51c2abcfec
I got also a classical gauge one, but it vibrates so badly with the short intakes of the engine, that I cannot advise it.
See you,
Lluís
