Old 04-12-2013, 11:06 AM   #1
vx220
Default small block vaux vs 7 port a series
Hi,
If you were paying someone (albeit mate's rates) to do your coversion, does it make sense to spend money on a nice a series (mild 7 port/5 speed?) and less on the labour involved around a Vauxhall conversion (although the vaux probably will have power/longevity and cheap replacements if anything fails on its side)
Ball park figures, but a 7 port with bike carb/megajolt and a 5 speed will cost £7k-ish but will basically drop in (assuming mini is in good nick)
Buying all the bits for the vaux will probably cost half that (small block/diesel box/bike carbs/megajolt) but will cost loads more in labour (despite mate's rates!)
Any thoughts?
vx220 is offline   Reply With Quote
Old 04-12-2013, 11:55 AM   #2
I cant waight for this hornets nest to unfold,
leave the 7 port and the 5 speedbox out of it as them 2 things are doubleing the cost for not a lot of gain,,
im fully hearing your point and I love the [A] in a way
but thers no comparison to a 1.4 rover]1.6 v,tec] 1.3 16v susuki] ect ect,
must be done,no comparison,
Old 04-12-2013, 12:26 PM   #3
Got to say, once you realise that the people saying "it'll mess up the handling!" are talking out of their ar$es, it's very hard to consider a tuned A series. Most of us on the forum have had tuned A's before, and that's why we're here.
Old 04-12-2013, 12:52 PM   #4
gimenofl
gimenofl's Avatar
CC: 1380
ECU: Typhoon Specialist Co.
Hi Vx,
Look, no seven port, but I put on a Specialist Components K1100 LT engine in my mini 5000Km ago. 138.5 hp on dyno, very flat torque. Driven daily.
I drive rather hard, it was in Zandvoort circuit as well. No problems what so ever so far, other than a light leak from the head gasket sealant, to be replaced at no cost.
In other words, I think that what ever you do, do it right. I have seen bad A-series and bad engine conversions.
Would I have been in the UK without need for new paperwork and the risk of having legal problem I would most certainly have gone D-series (due to gear ratios on 10" wheels). But here in The Continent, the K1100 head is just fabulous.
Lluís
Old 04-12-2013, 01:16 PM   #5
Andy_S
Andy_S's Avatar
ECU: Megasquirt ... kinda
This is one of those questions which can't easily be answered in a manner that shows that one route is 'better' than the other.
It's true that the 'off the shelf' power from an engine swapped Mini is very reliable, but invariably there's compromises and mechanical problems elsewhere in the car so even though the engines are almost bomb proof, other bits of the car tend to be a headache.
The fancy a-series option requires a big up-front investment and if you're not careful you'll get an overstressed engine & box but there aren't going to be so many compromises and odd-ball mechanical problems elsewhere on the car.
Both options require proper suspension setup so you don't gain either way.
So..........
IMHO you should only go for an engine swapped Mini if it's something that you really want to acheive. If you've got a pot of money and you want a fun powerfull Mini straight out of the box then a tuned a-series would be my first choice.
Old 04-12-2013, 07:36 PM   #6
lol, Mini Mag have put up a pic of a Zetec engined mini on Facebook and cue the usual comments. One guy has posted "but how does it go around corners ?" I'm so tempted to put "by turning the steering wheel"
Old 04-12-2013, 07:45 PM   #7
classic,lol
Old 04-12-2013, 07:53 PM   #8
Kaison
Kaison's Avatar
You're welcome.
I only bow under braking.
Old 04-12-2013, 08:04 PM   #9
Haha just went and had a look at that, there are a looot of people out there that hate valvers!
Old 04-12-2013, 08:08 PM   #10
Kaison
Kaison's Avatar
That's what makes it so appealing. . . and yet when someone slams a Mini to the ground and ruins ALL it's driving characteristics, no one raises and eyebrow, they all applaud.
Old 04-12-2013, 08:18 PM   #11
vx220
Thanks for comments guys
Not worried about handling, well aware of a series bulk
Just looking for an easy way to 5speed and 110-ish horsepower
Daily drive, but usually small distances
Need something that feels fast without being licence losing, and makes "everyday a trackday"
Old 04-12-2013, 09:31 PM   #12
apbellamy
apbellamy's Avatar
ECU: SC Typhoon
Why 5 speed? Spec your 4 speed box properly (gear ratios and final drive in combination with wheel and tyre size) and it will be fine.
Doesn't matter what engine you choose, if you buy a tired old second hand engine, be it a metro 1275 or a K series etc, you are getting a used engine and it's very unlikely that you will be able to verify it's condition. I would always gather parts and build a fresh engine no matter what I was fitting. Costs more, but you know what you are getting.
I've seen countless people who have spent plenty of money on an aledgedly hot A series only to find out it's been put together by a ham fisted grapes. A lot of them then end up on here, start a conversion and then sell up as it's harder than they thought and minis are bananas
Old 05-12-2013, 01:11 PM   #13
Originally Posted by Kaison View Post
You're welcome.
lol
Old 05-12-2013, 02:07 PM   #14
gimenofl
gimenofl's Avatar
CC: 1380
Agreed with Apbellamy, gear spacing and ratios is critical. In case you have €€€ and little time go for a Specialist Components 16V of a gas flow head and 2.9 FR (3000rpm on 10" at 100 km/h) or a nice MED. In case you want a modern conversion, look at the many options you have from Honda to Vauxhall and decide on subframe or make your own.
I think that what is fundamental is that either way you get a GOOD engine and a GOOD set-up.
Old 07-04-2014, 09:52 PM   #15
minimutley
ECU: pinto dizzy, bike carbs
Some very sensible replies here, a tuned a series, done well on a good engine base is a wonderful fun drive (1380 my favourite). I'm guessing that a k1100 would be even better, and selecting the right FD to take advantage of the increased torque should only improve things.
Having direct experience with a (std) 1600k series on dellorto carbs, made me wonder what a tuned 1.8 would be like?? The 1600 went like stink, I was grabbing gears like it was a motorbike,but a head rebuild (ingested piece of bananas air filter housing) with a std steel front end was a pig.
One thing is certain, building and maintaining one is not simple, especially if you're trying to fit it into a std front end, and you only have to see how long most people spend building these machines. Done badly it's a nightmare...
One other point, modern turbo diesels have so much mid range torque these days it makes most NA cars feel slow, turbos give so much kick they're hard to beat - petrol or diesel (or lpg if you have room for a tank).
Huw
minimutley is offline   Reply With Quote
