Old 22-05-2019, 11:39 AM   #1
gav
ECU: Emerald
Default Cable speedo adaptor
Has anyone found a good electronic to cable speedo adaptor? My engine has an electronic VSS but I want to use a cable speedo, I found this but seems a little pricey https://www.speedhut.com/Speedbox.html
gav is offline   Reply With Quote
Old 22-05-2019, 12:13 PM   #2
Haz
ECU: Hondata S300
Not an exact answer to your query but I'm using a GPS speedo from speedhut, no cables or drive to worry about
Old 22-05-2019, 12:44 PM   #3
250ptm
250ptm's Avatar
ECU: odb1
I don’t get it!
Is this all about the look?
Mechanical speedos are notoriously inaccurate without being driven by an electronic “speedhut” interface.
Since you already have a honda vss (which is electronic output) then use this:
http://store.centrodyne.com/store/Y0...vider-P72.aspx
with a classic looking digital gauge of your choice.
Accuracy can be less than (1mph) and in most cases will be programmable for wheel /diff combos.
Old 22-05-2019, 12:53 PM   #4
gav
ECU: Emerald
Yeah I wanted to use the original clocks if possible (it's a Metro).
Old 22-05-2019, 01:12 PM   #5
250ptm
250ptm's Avatar
ECU: odb1
Ok.
I’m sure this has been done before, I remember reading someone (on this site) converted an original speedo face and dial for a digital input, sorry but I can’t find the link!!!! Perhaps someone else will chime in.
Old 22-05-2019, 02:33 PM   #6
Haz
ECU: Hondata S300
There was this thread https://www.16vminiclub.com/showthread.php?t=37880 relating to using the mini speedo, not sure how relevant this is for a metro though?
What motor are you using now Gav? I should have that B18 fired up next week if all things go to plan... famous last words
Old 23-05-2019, 09:52 AM   #7
gav
ECU: Emerald
Thanks I'll have a read K20 now, am missing that engine already!
Old 23-05-2019, 01:42 PM   #8
Haz
ECU: Hondata S300
Looking forward to giving it some welly
Nowt wrong with a k20, I had en ep3 for 7 years. Sold it with 115k on the clock and 248bhp, still felt as tight as it did at 12k and 197bhp! Great engines.
Old 24-05-2019, 10:14 PM   #9
l_jonez
ECU: Megasquirt and ITB's
Might be worth contacting caerbont Automotive (Smith's)
They still make the metro dash, all be it a modern version for London taxis. They might have a option for you?
