#1 |
Make: Toyota
ECU: greddy
so got myself a 90 mini city thats very solid and an ep82 starlet donor car.
any tips or problems i am going to run into? any info would be great ![]() |
#2 |
Make: Toyota
if you head over to aus mini you will find just about all the info need .
I am myself just starting this very same thing but using the ep85 gearbox with is awd with the 4efte engine should be fun. look forward to your build |
#3 |
Due to lack of good suzuki engines here, I'm also looking in this direction.
#4 |
#5 |
CC: 1330
Make: Toyota
I have just finished my 4efte mini. Here is a link to my build on turbo minis:
http://www.turbominis.co.uk/forums/i...=vt&tid=470448 The only thing is i had to have the turbo poking out the grill a little. I used the Allspeed suzuki frame and modified to get different mounting points. Was fairly straight forward, you'll love it when its finished. Mines running about 150bhp and its brilliant fun! |
#6 |
ECU: Obd0 crx
Adam t I just looked at your build I seen your mini in magor services I was in my blue Vtec mini think you seen it as you drove past
#7 |
CC: 1330
Make: Toyota
Hi Johny, yeah i did see your mini at the services. I was on my way back from jap fest at castle coombe. Did you go as well?
Where abouts do you live? I would love take a closer look at yours. I'm doing the london to Brighton run this weekend. might see you there if your going |
#8 |
ECU: Obd0 crx
Hi Adam funny enough I was at japfest as well I got it on the rolling road down there I am from Ebbw vale gwent.
Did you have much fun with the jap cars on the way home I did lmao I would love to be going to London but lack of funds is stoping me from going ![]() |
Thread Tools | |
Display Modes | |
