Old 18-06-2012, 08:16 PM   #1
4efteMini
4efteMini's Avatar
CC: 1331
Make: Toyota
ECU: E-Manage Ultimate
Question 4efte engine conversion subframe
Hello
Within the next week im going to be getting a starlet gt 1.3 turbo and will be putting the engine in my round nose mini, now i am undesided on what rought to go with the subframe. The options i am looking at are either getting the bare suzuki subframe from all speed and modifying it or i could give it a go and try and make one myself.
My questions are
1) Would the suzuki subframe fit the starlet engine with a bit of modification.
2)What is the best option bearing in mind money and time it would take.
4efteMini is offline   Reply With Quote
Old 19-06-2012, 07:31 AM   #2
Beavis
Beavis's Avatar
CC: 1500cc
Make: Toyota
ECU: Link Storm
there has been a few starlet conversion so they should be able to help you out
http://www.mpdesign.id.au/engineconversion/start.htm
Old 19-06-2012, 03:04 PM   #3
4efteMini
4efteMini's Avatar
CC: 1331
Make: Toyota
Ok thank you for the reply that page will be a great help to me
Old 19-06-2012, 06:27 PM   #4
Beavis
Beavis's Avatar
CC: 1500cc
Make: Toyota
ECU: Link Storm
I built my own subframe to mount my engine , it is a lot of work , more if you have to change the suspension points . I was going to do the same conversion but the cost of a motor and everything else is crazy in new zealand .
Old 20-06-2012, 05:10 PM   #5
4efteMini
4efteMini's Avatar
CC: 1331
Make: Toyota
Ye I think I will give it a go my self then if I don't think it's much good will get the allspeed Suzuki subframe and modify that
Old 20-06-2012, 06:25 PM   #6
Beavis
Beavis's Avatar
CC: 1500cc
Make: Toyota
ECU: Link Storm
you do realise that a gready emanage is just a piggy back ah ?
Old 25-06-2012, 08:20 AM   #7
4efteMini
4efteMini's Avatar
CC: 1331
Make: Toyota
Ye i no that e manage is just a piggy back, whys that?
Old 25-06-2012, 08:41 AM   #8
Beavis
Beavis's Avatar
CC: 1500cc
Make: Toyota
ECU: Link Storm
have you looked at going for a dta or link ?
how much have you got of the original system ?
Old 27-06-2012, 06:37 PM   #9
4efteMini
4efteMini's Avatar
CC: 1331
Make: Toyota
I have the hole car so was just thinking of using that? Sorry I'm a bit of a newbie lol
Old 02-07-2012, 04:39 AM   #10
ewok6d
Make: Toyota
you should be able to use the factory ecu if you check out ausmini there is lots on info on there as well as this site ! im just starting one myself look forward to seeing how you go
ewok6d is offline   Reply With Quote
Old 02-07-2012, 06:24 AM   #11
Beavis
Beavis's Avatar
CC: 1500cc
Make: Toyota
ECU: Link Storm
if you have the whole car then you should be ok i am doing the same cause the vvti and imobliser is to much to deal with if you dont have everything
Old 09-07-2012, 04:24 PM   #12
4efteMini
4efteMini's Avatar
CC: 1331
Make: Toyota
Ok thanks for the help started stripping it all out last weekend get a few penny's together before I start lol planning on engine out and front off of the mini next
Old 17-09-2012, 08:39 PM   #13
johny
ECU: Obd0 crx
my next project is going to be a glanza engine will keep my eye on these posts
johny is offline   Reply With Quote
Old 12-10-2012, 08:22 PM   #14
Adam.t
CC: 1330
Make: Toyota
I started my conversion in July. I used the suzuki allspeed frame, fits the starlet engine nicely with a bit of modification. Had to move the back lower crossmember up to clear the gearbox and cables. Then weld on extra bits for the engine mounts. It can't post pictures yet but here is the link to my thread on turbo minis
turbominis.co.uk/forums/index.php?p=vt&tid=470448
Adam.t is offline   Reply With Quote
Old 15-11-2012, 10:17 AM   #15
g13bmini
ECU: DTA MBE OMEX
Also doing the 4efte engine conversion, this is first mini project I've attempted its for a friend so I joined this forum for advice of any kind,
Car specs will include a deep green respray with carbon trim,
Metro 4 Pots
A removable Front ?
Coilover Suspension
EPAS steering
Trying to keep it simple and doing all the work I will start a Build thread but only when the project gets underway,
Sent from my BlackBerry 9320 using Tapatalk
g13bmini is offline   Reply With Quote
