Old 17-04-2012, 03:37 PM   #1
claudio_cl
claudio_cl's Avatar
Make: Toyota
Send a message via MSN to claudio_cl
Default 4efte issue
Hello,
I am new to the forum, I'm from chile (my English is not good) and I'm building a mini round nose with a 4efte, I'm in the process of mounting the engine in the subframe that I did, but I have a pretty big question. .. I want to see how to do a traction, I have studied the issue and I think I have to put the spindles (or whatever says in english) of glanza with constant velocity and mass using the mini slide and machined the mass of glanza? have some photos to the measures did ... maybe the question ought to be, as I do for this step, use the mini and constant velocity around the axis, using everything from bears glanza least mass?
Mass of Glanza
Spindle of mini without bearings
mass + splindle
I want this!
That's the way or how yours do this always...
I use Google Traductor
I Hope can help me
claudio_cl is offline   Reply With Quote
Old 17-04-2012, 06:52 PM   #2
Beavis
Beavis's Avatar
CC: 1500cc
Make: Toyota
ECU: Link Storm
Morning
So what you are trying to do is use the glanza drive flange in a mini hub ?
You are going to run in to a lot of issues,
-modifying bearing setup to fit the different sizes
-how are you going to mount the disk rotors ? glanza or mini ?
-what brake calipers are you going to use toyota / mini / aftermarket ?
-glanza cv joints do they fit the mini / toyota combination
making adaptor drive shafts is a easier way to go
well that my opinion
Old 17-04-2012, 07:39 PM   #3
claudio_cl
claudio_cl's Avatar
Make: Toyota
Hi, thanks for your reply,
Well in this moment i don't know how to do, i have the complete parts of toyota and mini axle's, cv joints, hubs, calipers.
If the easy way is put a adaptor for the drive shaft i do that, but how? have and pics? link? some idea? sorry if a ask soo much
the you says drive shaft do you mean a conjuction of cv joint and axle? the idea is machining the axle to put in a mini CV??
Regards
Old 17-04-2012, 10:35 PM   #4
windymiller
windymiller's Avatar
Here's how I did mine:
Cut the Toyota drive shaft and the mini driveshaft and weld them together. You can add a sleeve to the joint for extra strength. Hope this helps. You must make sure the shafts are straight after welding or you'll get bad vibrations.
Re-build with Rover 1.8 vvc:
Old 18-04-2012, 02:42 PM   #5
claudio_cl
claudio_cl's Avatar
Make: Toyota
Thanks! I was thinking the same but not shure if this welding have the same strength of original driveshaft, i hope the CV joint can hold the power of the engine.
Thanks and now go for this...
Only have to see if i can put the brakes of toyota, someone have do this?
Regards.
Old 19-04-2012, 01:07 PM   #6
arterz
arterz's Avatar
ECU: OBD0
most conversions here are based on cut/welding method of mixed driveshafts.
this is my axles , hope that helps too
mitsos mini 16v
Old 23-04-2012, 04:16 PM   #7
claudio_cl
claudio_cl's Avatar
Make: Toyota
Thanks for the replys!!! today I send to machined the drive shaft's to do this, and put a sleeve por more protection, when this is finished I put some pics!!
Old 26-01-2014, 03:03 PM   #8
cooperS
CC: 1331cc
Make: Toyota
ECU: Blitz Access ECU
Send a message via MSN to cooperS
Hola Claudio
de donde eres? yo mande a hacer los ejes y uso
homocineticas de Mini, quedaron perfecto!
slds
AJ
cooperS is offline   Reply With Quote
Tags
4efte, axle, shaft
