Old 21-12-2010, 07:33 AM   #1
jon
Default traction problems
Hello everyone. I'm new to the club and I have a few questions regarding a Starlet GT engine install. Is there any traction at all, even with a standard 130HP on tap? I read somewhere about a limited slip diff that's available for the Toyota engine / gearbox install to help with traction. Any ideas if this is available or able to be done?
jon is offline   Reply With Quote
Old 21-12-2010, 12:52 PM   #2
mininut
ECU: Trionic 5.5
There's a fantastic way to make sure you always get traction, not many people are wise to this... right foot control, use heavy weights and build up the muscles that control the foot, this will allow you to get traction in the toughest of conditions.
oh, and welcome.
M.
Old 23-12-2010, 05:02 AM   #3
mearcat
CC: 1331
Make: Toyota
There is a TRD LSD available but can be quite hard to find. If you can't find one, the best alternative is as mininut said - your right foot (and some softer compound tyres )
On a side note, you may also consider fitting a equalising shaft from a 4AGE (and a custom bracket to hold it onto the block) to get the two outer driveshafts within ~30mm length of each other in an attempt to alleviate torque steer (assuming that the suspension is also set up well)
mearcat is offline   Reply With Quote
Old 23-12-2010, 10:08 PM   #4
windymiller
windymiller's Avatar
Which 4AGE install had the equaliser shaft? I've fitted one from an MR2 and the driveshafts are 500mm and approx 275mm! Think I'll be heading for the first ditch when I get it on the road.....
Re-build with Rover 1.8 vvc:
Old 27-12-2010, 09:18 AM   #5
best_stig
CC: 1330
Make: Toyota
ECU: Adaptronic
Send a message via MSN to best_stig
I have a feeling its the 4agze, or the silvertop 20v.
Not totally sure which, i have mine already.
best_stig is offline   Reply With Quote
Old 28-12-2010, 11:44 AM   #6
jon
Thanks for the help guys, I like the right foot control idea
Old 11-05-2011, 06:15 AM   #7
Mini Mad
CC: 1330
Make: Toyota
ECU: Autronic SM4
Send a message via MSN to Mini Mad
I get plenty of traction on low boost ~150HP/10psi
Quaife LSD, 10" A032R's - good wheel alignment
Traction becomes an issue at higher boost levels..16-22psi but right foot control helps.
My aftermarket computer is also setup for gear/speed boost control so that as the speed increases and gear we can ramp the boost up to take advantage of the extra traction. This is a lot of work to setup properly though.
Mini Mad is offline   Reply With Quote
Old 04-08-2011, 07:00 AM   #8
minisprouts
Make: Toyota
ECU: standard EDU
Send a message via Yahoo to minisprouts
I also swapt my mini GT engine with 4EFTE engine, when kick down the front body lifthing so it change all the chamber and the car is uncontrolable. Later I tight the lower arm so the the lifth can only to a certain level, but this is the dummy process and I wonder if anyone facing the same problem for the front body lifthing due to strong engine power.
minisprouts is offline   Reply With Quote
Old 04-08-2011, 07:51 AM   #9
Mini Mad
CC: 1330
Make: Toyota
ECU: Autronic SM4
Yes, the front of the car will lift under heavy acceleration.
There are a couple of things you can do - raise the rear of the car and you can also put in hydro competition rear bumpstops - which helps stop the squat at the rear.
Old 04-08-2011, 06:29 PM   #10
limit straps will stop the lift, but will redice traction and mask the inherent problem. you need to reduce or eliminate bump steer.
Old 05-08-2011, 03:33 AM   #11
Mini Mad
CC: 1330
Make: Toyota
ECU: Autronic SM4
What are limit straps? where/how do you install them? Any Pics?
What are the trade-offs?
Old 07-08-2011, 07:08 PM   #12
there not a good idea, they will reduce traction, and they only mask an underlying problem
Old 19-12-2012, 07:17 AM   #13
Kingsley Aghedo
Reversing the fork actually makes the handling more stable but it makes the bike feel sluggish when turning. I've ridden my Bike Friday with a reversed fork and the main problem was that the bike was much more prone to lifting the rear wheel under hard braking. I agree with the choice to move the battery weight to the front instead, especially if you can mount it fairly low. Traction is primarily a function of the weight on the wheel and the tire compound. There shouldn't be a need to go with a bigger, lower pressure tire.
Kingsley Aghedo is offline   Reply With Quote
Old 19-12-2012, 09:03 AM   #14
PaulW
PaulW's Avatar
ECU: Megasquirt MX5 Pnp
Did you copy and paste that straight off the internet its a car forum and although i haven't clicked the links on your post i bet its selling some bananase The post is very old as well.
Paul
