Old 09-02-2011, 04:20 PM   #31
Marco
Make: Toyota
ECU: Dictator
just a nother pic
Marco is offline   Reply With Quote
Old 15-02-2011, 12:52 PM   #32
Quadra
Quadra's Avatar
Marco
This is just an observation, but are you sure that you have used that engine in the correct orientation. Under acceleration the engine will try to rotate backwards and forwards around the driveshafts as the torque is transferred to the road, the engine and gearbox mounts should try try to resist this, but you have created a pivot rather than as restriction, I think the engine mount needs to be rotated 90 degrees to help stop the engine titling backwards and forwards. i.e. the bolt through the mount needs to point front to back not side to side.
Mike
Quadra is offline   Reply With Quote
Old 15-02-2011, 08:25 PM   #33
Marco
Make: Toyota
ECU: Dictator
Jip the engine will pivit but there are two mountings in the front next to the exhaust and im planning to make a plan for the back of the engine as well to prevent it from piviting to the front and back and hopfully this would help, its difficut to move the mounting as there isnt really space the engine is a bit too big but will find out one day.
Old 15-02-2011, 08:32 PM   #34
Marco
Make: Toyota
ECU: Dictator
Its got nothing to do with minis but its a pretty awsome clip of a honda S2000 turbo called HONDA FROM HELL.
Old 16-02-2011, 07:26 AM   #35
arterz
arterz's Avatar
ECU: OBD0
Hi I know a greek astra F with C20LET @ 750 PS is too fast as S2000 but look what did it do to the gsxr 1000:
the guy "kontraman" has more videos on youtube,
absolute madness
sorry for the off topic
nice job,keep working on the mini
mitsos mini 16v
Old 21-02-2011, 09:31 AM   #36
Wolfhound
Make: Toyota
ECU: Go-Tech
That's Cool Evolution, my message about the flimsy frame didn;t come from your comment, it was in reply to message No 20 from Marco.
All good.
Wolfhound is offline   Reply With Quote
Old 21-02-2011, 04:35 PM   #37
Marco
Make: Toyota
ECU: Dictator
21 February 2011 The manifold plate is made of 1cm mild steel.
Old 21-02-2011, 04:49 PM   #38
Marco
Make: Toyota
ECU: Dictator
21 February 2011 Further progress on my subframe almost finished
Old 21-02-2011, 09:59 PM   #39
windymiller
windymiller's Avatar
Looking good mate - keep up the good work, I know how much of a pig these Toyota engines are to fit! If you have a look on my build page 1, 3rd photo down, you'll see the Toyota torque mount that I modified. I'm also going to fit a lower gearbox steady from a mini at the front, going from the subframe and picking up one of the mounting holes at the botom of the gearbox bell housing. Doing this (or something similar) should stop the engine twisting under load.
Re-build with Rover 1.8 vvc:
Old 28-02-2011, 06:42 PM   #40
truwel
nice proyect!
i would wanna ask you, are you planing to run your gear box whit LSD?
truwel is offline   Reply With Quote
Old 01-03-2011, 02:22 PM   #41
Marco
Make: Toyota
ECU: Dictator
Nope just the plain 4age gearbox at this time.
Old 01-03-2011, 07:04 PM   #42
Marco
Make: Toyota
ECU: Dictator
23 February 2011. Bought hi-lows for my mini and painted a couple of goodies.
Old 01-03-2011, 07:10 PM   #43
Marco
Make: Toyota
ECU: Dictator
1 March 2011 Sprayed red oxide on my front sub frame followed by black stone chip paint.
Old 03-03-2011, 06:24 PM   #44
ivandaslow
ivandaslow's Avatar
CC: 1587
Make: Toyota
ECU: Gotech
Default nice build
hey marco, the build is looking good! Glad to see everyting is begining to fall in to place. Have you decided on what you gonna do regarding mags (size and design) and colour?
ivandaslow is offline   Reply With Quote
Old 04-03-2011, 04:20 PM   #45
Marco
Make: Toyota
ECU: Dictator
well my perents promised me a set of rims im looking for 13inch mini lights with black inserts
