Old 16-11-2010, 06:03 PM   #1
Marco
Make: Toyota
ECU: Dictator
Default 20 Valve Mini in progress
My 1275 mini which I purchased on the 19 August 2010
Marco is offline   Reply With Quote
Old 16-11-2010, 06:17 PM   #2
Marco
Make: Toyota
ECU: Dictator
20 August 2010
Started to strip the car
And found out the calipers are held together with nails
Old 16-11-2010, 06:25 PM   #3
Marco
Make: Toyota
ECU: Dictator
20 August 2010 Stripped the interiour only to find rust
Old 16-11-2010, 06:29 PM   #4
Marco
Make: Toyota
ECU: Dictator
24 August removed engine, gearbox and suspention.
And some small things inside.
Old 16-11-2010, 06:34 PM   #5
Marco
Make: Toyota
ECU: Dictator
26 August removed the front subframe
Old 16-11-2010, 06:38 PM   #6
Spiyda
Originally Posted by Marco View Post
20 August 2010
There's a lot less rust on that shell than the one we used... !
looks like you got a good one
and tbh those nails were probably stronger than the special split pins that should be fitted.. so safety wasn't compromised.... I've done the same myself when I couldn't find a good split pin..
Old 16-11-2010, 06:40 PM   #7
Marco
Make: Toyota
ECU: Dictator
31 August 2010 Started to sand down body to remove the seams then discoverd rust underneath the body filler. So i fixed both sides and further removed the seams on the body.
Old 16-11-2010, 06:47 PM   #8
Marco
Make: Toyota
ECU: Dictator
6 November i went about buying my engine first tried engine den their price wasn't too bad but they just wasnt bothered to help so we left and went to a shop called jap engines purchased the motor and gearbox, when we got back we lifted the engine onto the table and found out it had no compression. we quickly exchanged the engine and the second one felt much better, Got a 2 month guarantee so i will have to hurry with the subframe and wiring..
I replaced the clutch and pressure plate as well and removed the throttle bodies plastic box thingy.
Old 16-11-2010, 06:57 PM   #9
Marco
Make: Toyota
ECU: Dictator
4 November 2010
I cut away the minis front body to make life easyer. Had to remove the altenator will relocate it some other day. The engine is on the lift this is to get a rough idea how the engine and gearbox will be mounted. I stuck masking tape to close the throttles.
Old 16-11-2010, 07:05 PM   #10
Marco
Make: Toyota
ECU: Dictator
16 November 2010 The sump was catching on the suspention arms so they were cut down and sprayed the sump with heat resistent black spray. Also went to a large engine spares shop and they didnt have any sump gasket seal so insted i just bought a new thermostat for luck
Old 16-11-2010, 07:10 PM   #11
Welcome Marco. Looks interesting. Allways nice to see a different engine conversion. It's going to be quite tight for room by the looks of it in the bulkhead area and is that the oil filter housing at the front very close to the tie bar? Looks like a nice challenging build.
Old 17-11-2010, 10:41 PM   #12
windymiller
windymiller's Avatar
Looking good Marco. Good luck with the build, the car should fly with the 20v in it
Re-build with Rover 1.8 vvc:
Old 18-11-2010, 10:08 AM   #13
apbellamy
apbellamy's Avatar
ECU: SC Typhoon
Looks good.
If you are deseaming the rear quarters/rear panel joins, weld it up from the inside before removing the seams on the outside. It will save you having to weld up a big gap and risk the shell distorting
Old 18-11-2010, 05:29 PM   #14
Marco
Make: Toyota
ECU: Dictator
18 November 2010 made a gasket for the sump and replaced the oil filter, Spark plugs, thermostat and the oil.
Old 18-11-2010, 05:36 PM   #15
Marco
Make: Toyota
ECU: Dictator
18 November 2010 The side shaftes and C.Vs will need to be machined to fit the minis hubs. The first phots shows the old shafts and on the gearbox is the new stronger ones.
