Old 10-12-2013, 10:40 AM   #31
mini-type-r
Well observed. But it does "jiggle" a bit when i drop the power. Thursday we are doing the wheels, some toe-in up front and i think??? toe out at the rear (as it is rwd). Ill test it a bit.
mini-type-r is offline   Reply With Quote
Old 10-12-2013, 06:53 PM   #32
mini-type-r
Hmm 0,5 toe in front and 0,5 toe in rear (not toe out) i guess, any experts?
Old 10-12-2013, 07:10 PM   #33
Front should be either parallel or slight toe out say 1/16th of an inch. Rear toe in standard mini setting or work towards parallel, but I'd leave rear as std mini setting.
Old 10-12-2013, 08:24 PM   #34
mini-type-r
Hmm its a bit unclear for me but a similar car (Sylva Riot) has 0,3 degrees toe in at the front (Caterham settings) and 22 minutes (uhm ? how many degrees is that?) toe in at the rear (Elise settings).
The car drives really well an the steering is nice and progressive he says.
